I just had another bunch of warnings regarding the handler in my log. I am using a fresh installation of OH2 (one day old). This time there is no rule involved. I used a group item to trigger all lights of:
15:50:42.181 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Lights' received command OFF
15:50:42.189 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedroom_Lights' received command OFF
15:50:42.201 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light12_Brightness' received command OFF
15:50:42.205 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bathroom_Lights' received command OFF
15:50:42.223 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light14_Brightness' received command OFF
15:50:42.224 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hall_Lights' received command OFF
15:50:43.234 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Livingarea_Lights' received command OFF
15:50:43.237 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light17_Brightness' received command OFF
15:50:43.250 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Livingroom_Lights' received command OFF
15:50:43.259 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kitchen_Lights' received command OFF
15:50:44.278 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light13_Brightness' received command OFF
15:50:44.278 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Office_Lights' received command OFF
15:50:44.298 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Outdoor_Lights' received command OFF
15:50:44.300 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Livingroom_Lights' received command OFF
15:50:44.316 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ZW_DRS1_Switch' received command OFF
15:50:44.320 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Kitchen_Lights' received command OFF
15:50:45.327 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Command received zwave:device:controller:node5:switch_binary --> OFF
15:50:45.327 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 5: Creating new message for application command SWITCH_BINARY_SET
15:50:45.328 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
15:50:45.328 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
15:50:45.330 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 05 03 25 01 00 25 9C 7D
15:50:45.331 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0A 00 13 05 03 25 01 00 25 9C 7D
15:50:45.337 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ZW_DIM1_Dimmer' received command OFF
15:50:45.338 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ZW_WP3_Switch' received command OFF
15:50:45.343 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
15:50:45.345 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:50:45.346 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
15:50:45.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
15:50:45.348 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
15:50:45.348 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
15:50:45.360 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 9C 00 00 02 75
15:50:45.362 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:50:45.363 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 9C 00 00 02 00 00 7B
15:50:45.364 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 9C 00 00 02 00 00 7B
15:50:45.365 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9C 00 00 02
15:50:45.366 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 156, Status = Transmission complete and ACK received(0)
15:50:45.366 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
15:50:45.366 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@92ac80 already registered
15:50:45.367 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=156, payload=05 03 25 01 00
15:50:45.368 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9C 00 00 02
15:50:45.369 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=156, expected=SendData, cancelled=false transaction complete!
15:50:45.369 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
15:50:45.370 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
15:50:45.370 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 37ms/4361ms.
15:50:50.344 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@1ddd675' takes more than 5000ms.
15:50:50.349 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@1ddd675' takes more than 5000ms.
15:50:50.345 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'zwave:device:controller:node9' takes more than 5000ms for processing event
15:50:50.351 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'zwave:device:controller:node11' takes more than 5000ms for processing event
15:50:50.352 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Command received zwave:device:controller:node11:switch_binary --> OFF
15:50:50.352 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 11: Creating new message for application command SWITCH_BINARY_SET
15:50:50.352 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Command received zwave:device:controller:node9:switch_dimmer --> OFF
15:50:50.354 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
15:50:50.354 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
15:50:50.356 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 9: Creating new message for command SWITCH_MULTILEVEL_SET
15:50:50.356 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0B 03 25 01 00 25 9D 72
15:50:50.357 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
15:50:50.358 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 25 01 00 25 9D 72
15:50:50.361 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light8_Brightness' received command OFF
15:50:50.374 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
15:50:50.377 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:50:50.378 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
15:50:50.379 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
15:50:50.381 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
15:50:50.381 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: Sent Data successfully placed on stack.
15:50:50.390 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 9D 00 00 02 74
15:50:50.393 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:50:50.395 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 9D 00 00 02 00 00 7A
15:50:50.396 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 9D 00 00 02 00 00 7A
15:50:50.397 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9D 00 00 02
15:50:50.398 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 157, Status = Transmission complete and ACK received(0)
15:50:50.399 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
15:50:50.402 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=11, callback=157, payload=0B 03 25 01 00
15:50:50.404 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9D 00 00 02
15:50:50.405 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=157, expected=SendData, cancelled=false transaction complete!
15:50:50.405 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
15:50:50.406 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
15:50:50.407 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Response processed after 48ms/4361ms.
15:50:50.408 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
15:50:50.410 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 09 03 26 01 00 25 9E 70
15:50:50.411 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 9: Sending REQUEST Message = 01 0A 00 13 09 03 26 01 00 25 9E 70
15:50:50.427 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
15:50:50.429 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:50:50.431 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
15:50:50.432 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
15:50:50.434 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
15:50:50.435 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 9: Sent Data successfully placed on stack.
15:50:50.447 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 9E 00 00 03 76
15:50:50.449 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:50:50.452 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 9E 00 00 03 00 00 78
15:50:50.453 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 9E 00 00 03 00 00 78
15:50:50.455 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9E 00 00 03
15:50:50.457 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 9: SendData Request. CallBack ID = 158, Status = Transmission complete and ACK received(0)
15:50:50.457 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
15:50:50.459 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@97101b already registered
15:50:50.462 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=9, callback=158, payload=09 03 26 01 00
15:50:50.465 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9E 00 00 03
15:50:50.467 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=158, expected=SendData, cancelled=false transaction complete!
15:50:50.467 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
15:50:50.468 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
15:50:50.470 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 9: Response processed after 57ms/4361ms.
15:50:50.523 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 26 03 00 DD
15:50:50.525 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:50:50.526 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 26 03 00 DD
15:50:50.527 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 26 03 00 DD
15:50:50.528 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 09 03 26 03 00
15:50:50.529 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
15:50:50.529 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
15:50:50.530 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@97101b already registered
15:50:50.530 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SWITCH_MULTILEVEL
15:50:50.531 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 9: Received SWITCH_MULTILEVEL command V3
15:50:50.532 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 9: Switch Multi Level report, value = 0
15:50:50.533 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
15:50:50.533 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
15:50:50.534 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 0
15:50:50.536 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Updating channel state zwave:device:controller:node9:switch_dimmer to 0 [PercentType]
15:50:50.542 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=9, callback=158, payload=09 03 26 01 00
15:50:50.543 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 09 03 26 03 00
15:50:50.545 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=158, expected=SendData, cancelled=false MISMATCH
15:50:55.370 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@1ddd675' takes more than 5000ms.
15:50:55.374 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'hue:0220:1:light8' takes more than 5000ms for processing event
15:50:55.373 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@1ddd675' takes more than 5000ms.
15:50:55.373 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing hue:0200:1:light17 takes more than 5000ms for processing event
15:50:55.389 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light9_Brightness' received command OFF
15:50:55.397 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light15_Brightness' received command OFF
15:50:55.420 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light10_Brightness' received command OFF
15:50:55.425 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light16_Brightness' received command OFF
15:50:55.445 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light18_Brightness' received command OFF
15:50:55.464 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light19_Brightness' received command OFF
15:50:55.476 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ZW_WP2_Switch' received command OFF
15:51:00.479 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'zwave:device:controller:node10' takes more than 5000ms for processing event
15:51:00.479 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing hue:0220:1:light13 takes more than 5000ms for processing event
15:51:00.480 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Command received zwave:device:controller:node10:switch_binary --> OFF
15:51:00.483 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 10: Creating new message for application command SWITCH_BINARY_SET
15:51:00.484 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
15:51:00.484 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
15:51:00.486 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@1ddd675' takes more than 5000ms.
15:51:00.486 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0A 03 25 01 00 25 9F 71
15:51:00.487 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0A 00 13 0A 03 25 01 00 25 9F 71
15:51:00.490 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light11_Brightness' received command OFF
15:51:00.498 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
15:51:00.500 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:51:00.501 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
15:51:00.502 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
15:51:00.503 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
15:51:00.503 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: Sent Data successfully placed on stack.
15:51:00.507 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ZW_WP3_Switch' received command OFF
15:51:00.509 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Command received zwave:device:controller:node11:switch_binary --> OFF
15:51:00.509 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 11: Creating new message for application command SWITCH_BINARY_SET
15:51:00.510 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
15:51:00.515 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light15_Brightness' received command OFF
15:51:00.517 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light8_Brightness' received command OFF
15:51:00.518 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 9F 00 00 02 76
15:51:00.521 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:51:00.522 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 9F 00 00 02 00 00 78
15:51:00.523 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 9F 00 00 02 00 00 78
15:51:00.524 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9F 00 00 02
15:51:00.524 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 159, Status = Transmission complete and ACK received(0)
15:51:00.525 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Starting initialisation from DONE
15:51:00.526 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=10, callback=159, payload=0A 03 25 01 00
15:51:00.527 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=9F 00 00 02
15:51:00.527 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=159, expected=SendData, cancelled=false transaction complete!
15:51:00.527 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
15:51:00.528 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
15:51:00.528 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Response processed after 40ms/4361ms.
15:51:00.529 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
15:51:00.530 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0B 03 25 01 00 25 A0 4F
15:51:00.530 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 25 01 00 25 A0 4F
15:51:00.543 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
15:51:00.544 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:51:00.548 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
15:51:00.548 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
15:51:00.552 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
15:51:00.553 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: Sent Data successfully placed on stack.
15:51:00.559 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 A0 00 00 02 49
15:51:00.561 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:51:00.563 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 A0 00 00 02 00 00 47
15:51:00.566 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 A0 00 00 02 00 00 47
15:51:00.567 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=A0 00 00 02
15:51:00.568 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 160, Status = Transmission complete and ACK received(0)
15:51:00.569 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
15:51:00.569 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@dae012 already registered
15:51:00.570 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=11, callback=160, payload=0B 03 25 01 00
15:51:00.572 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=A0 00 00 02
15:51:00.573 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=160, expected=SendData, cancelled=false transaction complete!
15:51:00.574 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
15:51:00.574 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
15:51:00.575 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Response processed after 44ms/4361ms.
15:51:01.551 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light16_Brightness' received command OFF
15:51:01.554 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light9_Brightness' received command OFF
15:51:02.581 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light10_Brightness' received command OFF
15:51:02.801 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light18_Brightness' received command OFF
15:51:02.817 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light19_Brightness' received command OFF
15:51:04.403 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 0A 08 32 02 21 74 00 00 00 00 92
15:51:04.406 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:51:04.408 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 0A 08 32 02 21 74 00 00 00 00 92
15:51:04.410 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 0A 08 32 02 21 74 00 00 00 00 92
15:51:04.412 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0A 08 32 02 21 74 00 00 00 00
15:51:04.413 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Application Command Request (ALIVE:DONE)
15:51:04.413 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Starting initialisation from DONE
15:51:04.414 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@13d5af0 already registered
15:51:04.415 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Incoming command class METER
15:51:04.415 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 10: Received METER command V3
15:51:04.416 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 10: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
15:51:04.416 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
15:51:04.417 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveMeterValueEvent
15:51:04.417 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 0E+1
15:51:04.418 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_KWh <> E_W
15:51:04.419 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating channel state zwave:device:controller:node10:meter_watts to 0 [DecimalType]
15:51:04.425 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_A <> E_W
15:51:04.426 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_V <> E_W
15:51:04.426 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Transaction not completed: node address inconsistent. lastSent=11, incoming=255
15:51:07.832 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing zwave:device:controller:node5 takes more than 5000ms for processing event
15:51:07.832 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing hue:0200:1:light18 takes more than 5000ms for processing event
15:51:07.834 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@1ddd675' takes more than 5000ms.
15:51:07.833 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@1ddd675' takes more than 5000ms.
15:51:07.857 [INFO ] [ome.event.GroupItemStateChangedEvent] - Lights changed from OFF to ON through Bedroom_Lights
15:51:08.889 [INFO ] [ome.event.GroupItemStateChangedEvent] - Office_Lights changed from OFF to ON through Hue_Light11_Brightness
15:51:08.893 [INFO ] [marthome.event.ItemStateChangedEvent] - ZW_WP2_Switch changed from ON to OFF
15:51:08.896 [INFO ] [ome.event.GroupItemStateChangedEvent] - Office_Lights changed from ON to OFF through ZW_WP2_Switch
15:51:08.901 [INFO ] [ome.event.GroupItemStateChangedEvent] - Lights changed from ON to OFF through Office_Lights
15:51:08.911 [INFO ] [ome.event.GroupItemStateChangedEvent] - Power changed from 9.095 to 5.1 through ZW_WP2_Power
15:51:08.942 [INFO ] [marthome.event.ItemStateChangedEvent] - ZW_WP2_Power changed from 3.995 to 0
15:51:10.192 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 13 06 31 05 03 0A 00 53 8C
15:51:10.194 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:51:10.195 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 13 06 31 05 03 0A 00 53 8C
15:51:10.196 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 13 06 31 05 03 0A 00 53 8C
15:51:10.197 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 13 06 31 05 03 0A 00 53
15:51:10.197 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 19: Application Command Request (INITIALIZING:PING)
15:51:10.198 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Node is ALIVE. Init stage is PING.
15:51:10.198 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
15:51:10.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 19: Node Status event during initialisation - Node is ALIVE
15:51:10.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 19: Node advancer - PING: queue length(0), free to send(true)
15:51:10.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 19: Node advancer: loop - PING try 1: stageAdvanced(false)
15:51:10.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 19: Node advancer: PING - send NoOperation
15:51:10.199 [DEBUG] [ndclass.ZWaveNoOperationCommandClass] - NODE 19: Creating new message for command No Operation
15:51:10.200 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 19: Node advancer - queued packet. Queue length is 1 [...]
