hello,
its me again with a question. First let me explain what im trying to do. At the moment iam using the innogy system and binding for a lot of items like doors and windows, temperatur and so on.
Inside innogy are scripts where i can select than when a window is open the temp inside this room should set to a low level. But cause of the problem that innogy(Livisi the new owner) might close their system i want to implement all this stuff in openhab.
Now the rule im trying to make:
rule "Absenkung"
Member of OSen changed
tim = now.toString("HH:mm") + " "
woFOffen = triggeringItem.groupNames.get(0).toString
if (triggeringItem.state == OPEN && rweVariablefbfa6f.state == ON) {
haa.postUpdate(tim + "Raum "+woFOffen+" offen im Winter, Heizung aus")
val GroupItem myTemp = woFOffen.members.filter[ i | i.name.contains("Settemp") ]
if (!myTemp.empty)
myTemp.members.forEach(i | i.sendCommand(10.0))
if (triggeringItem.state == CLOSED && rweVariablefbfa6f.state == ON) {
haa.postUpdate(tim + "Raum "+woFOffen+" geschlossen, Heizung an")
if (!myTemp.empty)
myTemp.members.forEach(i | i.sendCommand(i.lastState))
OSen is the group of all windows
rweVariablefbfa6f.state is ON if its winter
In the first step i try to find out in which room the window was opened. This works fine, but now
the name of this Group (of the room) is in a string. how can i change it to a real Group?
thanks for your help
Thank u it helps me a lot to understand but maybe i am blind or only too old to see. I have the name of a Group in a string val and i want to access the members of this Group. How must i define this in a rule ???
Thanks I looked at this example but it doesn’t fir for my needs.Maybe I didn’t explained correctly where my problem is. I made a little test rule:
var String tim = now.toString("HH:mm") + " "
rule "Test1"
Item Test received update
var String woFOffen = "Kueche"
//var GroupItem x = x.getItem(woFOffen).members as GroupItem
val myTemp = Kueche.members.filter[ i | i.name.contains("Settemp") ]
logInfo("Test","Msg="+myTemp+woFOffen)
if (!myTemp.empty)
myTemp.forEach(i | i.sendCommand(22.0))
This test rule works perfectly. But in the real rule I don't have the name of the group like "Kueche" in the test rule I only have a string called woFOffen which contains the name of the group for ex. "Kueche". But I found no way to access this . I can create a new group with the same name but that's not helpfull. So may I could explain better
You are my hero!!! After a little fix u forgot it works now like a charm.
val groupItem = ScriptServiceUtil.getItemRegistry.getItem(“Kueche”) as GroupItem
Thanks a lot and Merry Christmas to u.
