I’ve added stateDescription metadata to an item and set the options like:
0=idle
1=charging
2=discharging
Within OH3 UI I see the transformed state, but when using this item in HabPanel with the Dummy widget the interger value is shown. Even when I select ‘use server-provided format if available’.
I see the options coming from the API. Does the Dummy widget not support this?
Regards,
Bastiaan
