I’m pulling my hair here trying to figure this out. In OH1 I was able to put in the user/pass for it to work. Now… switching to OH2 I have binded Harmony and see it as a “thing” but can’t send any commands to it!! below is the logging.
13:22:55.895 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘Harmony_Activity’ received command REFRESH
13:22:55.903 [WARN ] [harmonyhub.handler.HarmonyHubHandler] - Command {]: Not a acceptable type (String or Decimal), ignorning
13:22:55.905 [WARN ] [harmonyhub.handler.HarmonyHubHandler] - Command {]: Not a acceptable type (String or Decimal), ignorning
13:23:09.401 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘Harmony_Fireplace’ for widget org.eclipse.smarthome.model.sitemap.Switch
13:23:09.408 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘Harmony_Fireplace’ for widget org.eclipse.smarthome.model.sitemap.Switch
13:23:09.412 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
13:23:31.275 [INFO ] [marthome.event.ItemStateChangedEvent] - Nest_last_connection changed from 2016-06-25T13:22:28.641+0000 to 2016-06-25T13:23:31.177+0000
13:23:43.107 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘Harmony_Activity’ received command ToggleBlinds
13:23:43.487 [WARN ] [rg.jivesoftware.smack.XMPPConnection] - Connection closed with error
net.whistlingfish.harmony.protocol.HarmonyProtocolException: Got error response [401.2]: Unauthorized policy write haDevice denied
at net.whistlingfish.harmony.protocol.OAReplyProvider.parseIQ(OAReplyProvider.java:61)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.util.PacketParserUtils.parseIQ(PacketParserUtils.java:440)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.tcp.PacketReader.parsePackets(PacketReader.java:170)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.tcp.PacketReader.access$000(PacketReader.java:47)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.tcp.PacketReader$1.run(PacketReader.java:81)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
13:23:48.115 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.ThingManager@1a0d27a’ takes more than 5000ms.
13:23:48.115 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing ‘harmonyhub:hub:HarmonyHub’ takes more than 5000ms for processing event
13:23:53.122 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing ‘harmonyhub:hub:HarmonyHub’ takes more than 5000ms for processing event
13:24:13.116 [ERROR] [harmonyhub.handler.HarmonyHubHandler] - Could not start activity
java.lang.RuntimeException: Failed communicating with Harmony Hub
at net.whistlingfish.harmony.HarmonyClient.sendOAPacket(HarmonyClient.java:270)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at net.whistlingfish.harmony.HarmonyClient.startActivity(HarmonyClient.java:368)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at net.whistlingfish.harmony.HarmonyClient.startActivityByName(HarmonyClient.java:377)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.openhab.binding.harmonyhub.handler.HarmonyHubHandler.handleCommand(HarmonyHubHandler.java:97)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.eclipse.smarthome.core.thing.internal.ThingManager$2.call(ThingManager.java:371)[104:org.eclipse.smarthome.core.thing:0.8.0.b5]
at org.eclipse.smarthome.core.thing.internal.ThingManager$2.call(ThingManager.java:1)[104:org.eclipse.smarthome.core.thing:0.8.0.b5]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:170)[98:org.eclipse.smarthome.core:0.8.0.b5]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: org.jivesoftware.smack.SmackException$NoResponseException
at net.whistlingfish.harmony.HarmonyClient.getNextPacketSkipContinues(HarmonyClient.java:282)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at net.whistlingfish.harmony.HarmonyClient.sendOAPacket(HarmonyClient.java:268)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
… 10 more
13:24:13.341 [WARN ] [rg.jivesoftware.smack.XMPPConnection] - Connection closed with error
13:24:32.537 [INFO ] [marthome.event.ItemStateChangedEvent] - Nest_last_connection changed from 2016-06-25T13:23:31.177+0000 to 2016-06-25T13:24:32.461+0000
13:24:37.703 [DEBUG] [overy.HarmonyHubDiscoveryParticipant] - StartScan called
13:24:37.712 [DEBUG] [onyhub.discovery.HarmonyHubDiscovery] - Creating Harmony server on port 44707
13:24:43.153 [ERROR] [harmonyhub.handler.HarmonyHubHandler] - Could not start activity
… 10 more
13:24:43.153 [WARN ] [software.smack.tcp.XMPPTCPConnection] - notifyReconnection()
at net.whistlingfish.harmony.HarmonyClient.sendOAPacket(HarmonyClient.java:259)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at net.whistlingfish.harmony.HarmonyClient.getCurrentActivity(HarmonyClient.java:358)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at net.whistlingfish.harmony.HarmonyClient$1.reconnectionSuccessful(HarmonyClient.java:140)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.tcp.XMPPTCPConnection.notifyReconnection(XMPPTCPConnection.java:914)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.tcp.XMPPTCPConnection.connectInternal(XMPPTCPConnection.java:825)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.XMPPConnection.connect(XMPPConnection.java:396)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at org.jivesoftware.smack.ReconnectionManager$2.run(ReconnectionManager.java:148)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
Caused by: org.jivesoftware.smack.SmackException$NotConnectedException
at org.jivesoftware.smack.XMPPConnection.sendPacket(XMPPConnection.java:584)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
at net.whistlingfish.harmony.HarmonyClient.sendOAPacket(HarmonyClient.java:267)[191:org.openhab.binding.harmonyhub:2.0.0.b3]
… 7 more
MY ITEMS FILE:
String Harmony_Activity “Current Activity [%s]” { channel=“harmonyhub:hub:HarmonyHub:activity” }
MY SITEMAP:
sitemap home label=“Main Menu” {
Frame {
Switch item=Harmony_Activity label=“Smart Blinds” mappings=[ToggleBlinds=“Open/Close”]
Switch item=Harmony_Fireplace mappings=[“Volume Up”=“Volume Up”,“Volume Down”=“Volume Down”]
