I need some clarification on using the Harmony Hub binding.
Currently I have a fully configured and working OpenHAB2 instance which I use to remotely control my Philips Hue bulbs (but nothing else, yet).
I have added the Harmony Hub binding, discovered my hubs, and discovered the things attached to each hub. I have located the page that lists all the possible button presses but have no idea how to pass the commands to the things themselves.
So far I have created a string item and linked it to one of the things but I can’t seem to move passed this.
I understand this concept, but it seems like the different commands are already mapped since they can be sent with the drop-downs in PaperUI. I feel like there should just be some way to access those instead of having to create the mappings in an Items file.
This has been the most confusing part of setting this up for me. And frankly, the documentation is a bit lacking when it comes to setting up the Harmony Hub. Nowhere does it tell you that you have to define the mappings.
I’m not a savvy coder, so I would appreciate it if someone could give a simple example of how to map a power toggle command as a switch (or button). Thanks.
Sure, I’m no savvy coder either, but I’ve managed to muddle together enough to control my heat pump - generally via lots of copy paste from other peoples items & sitemaps. Time to share!
My items line for the Harmony device (12345678 isn’t the device but you’ll get it, dunno what I should cloak)
Now, I’m not really using the PaperUI, just for setup purposes, I’m using classic so that I have it on my phone nicely via the app. The more you control how you want to interface with OpenHab the better it gets. Plus you get nice easy one shot buttons like that, rather than multi step selecting from a pull down and pushing buttons.
