Hi guys,
I run 2.5 M2 and have already updated the harmony binding to it’s latest snapshot. unfortunately my harmony keeps disconnecting. This is what I see in the logs:
2019-08-26 11:57:09.169 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub2' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected 2019-08-26 11:58:09.178 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub2' changed from OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected to OFFLINE (COMMUNICATION_ERROR): Could not connect: org.eclipse.jetty.io.ManagedSelector$$Lambda$288/0x97c47a28@13b852c
I must add that I noticed already that the harmony wifi connection is not very stable. it’s own LED switches from green to red (disconnected) from time to time. but even then, in the past, openHAB did always reconnect to the hub. This isn’t the case anymore.
If I restart everything, it will work again for a few hours/days.
Any idea how to fix, troubleshoot?
best regards
Stefan
