Does this work?
Per the docs:
…or a Player item can be used to send Play/Pause/FastForward/Rewind/SkipForward/SkipBackward.
Player HarmonyHubGreatPlayer { channel="harmonyhub:hub:GreatRoom:player" }
In my setup:
Item:
Player Living_Harmony_Player { channel="harmonyhub:hub:HarmonyHub:player" }
Sitemap:
Default item=Living_Harmony_Player
When trying the player selection, in the logs I see (for example):
2019-10-23 00:33:23.287 [ome.event.ItemCommandEvent] - Item 'Living_Harmony_Player' received command PAUSE
2019-10-23 00:33:23.290 [nt.ItemStatePredictedEvent] - Living_Harmony_Player predicted to become NULL
But the commands do not work. I can see the current harmony activity, and can issue a successful “buttonPress”, if I explictly state a device ID, for example:
String Living_Harmony_Denon "Button" { channel="harmonyhub:device:HarmonyHub:34311335:buttonPress" }
But I cannot get any response out of commands just sent to the “hub”:
String Living_Harmony_Button "Button" { channel="harmonyhub:hub:HarmonyHub:buttonPress" }
Is this normal? Do I need to map a “Pause” to a specific activity depending on which one is active for example? Seems like a pain to have to do that way. Am I missing something?
Thanks for the help!!
PS FYI: Using OH2 2.5.0.M4
