Hey,
I installed openhab2 on a raspberrypi. installed openhab2,which looks good.
then I installed the harmonyhub binding and was within the inbox for the hub to appear. But nothing happens.
Even if I force to search for it.
I installed then the network binding, this binding finds all devices. so it seems to work.
But why is it not working for the harmonyhub?
Can anybody help? Or at least tell me how to add the hub manually?
Thx for the reply.
I guess, it it the correct version. I Installed it trhough the paperUI.
Now, I added it manually, but got the following error out of the log files:
017-07-28 13:21:03.856 [ItemChannelLinkAddedEvent ] - Link ‘harmonyhub_hub_5ceaf4c1_currentActivity-harmonyhub:hub:5ceaf4c1:currentActivity’ has been added.
2017-07-28 13:21:03.955 [ThingAddedEvent ] - Thing ‘harmonyhub:hub:5ceaf4c1’ has been added.
2017-07-28 13:21:04.115 [hingStatusInfoChangedEvent] - ‘harmonyhub:hub:5ceaf4c1’ changed from UNINITIALIZED to INITIALIZING
2017-07-28 13:21:09.174 [hingStatusInfoChangedEvent] - ‘harmonyhub:hub:5ceaf4c1’ changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Could not connect: Failed communicating with Harmony Hub
Some time ago I’ve read about issues when the hub is connected through Access Points, Switches or whatever.
For testing, try direct connection between hub and your router …
thanks for the hint with the direct connection.
The solution was, that the hub needed to be connected to the original wifi and NOT to any guest wifi which I had setup.
