I am not sure how to check this but if you do know, let me know as i am anxiously waiting for this feature. Cheer
I assume it has, because there are PRs relating to it in the OH repo. (e.g. https://github.com/openhab/openhab2-addons/pull/1394)
Thanks. But, https://hudson.eclipse.org/smarthome/job/SmartHomeDistribution-Stable/changes is limited as it only shows changes of last 5 builds and not beyond. So, after going through the suggested links in WiKi, i am still not 100% whether this is included in latest openhab2 build.
It is not so hard, you need very little arithmetic. You ask about Refactoring bridge/thing life cycle. by sbussweiler · Pull Request #2087 · eclipse-archived/smarthome · GitHub. This says:
21 days ago makes something like Nov 11. Hudson tells you that the last stable build was done yesterday. So yes, this contains everything that has been merged up until yesterday - it is always building the ESH master branch.
Thank you for the clarification.
