normen
(Normen)
June 29, 2017, 4:40pm
1
I get an error from my window/door sensor in the openhab.log:
Endpoint 0 not found. Cannot set command classes.
And the behavior is, that I don’t get door status or temperature from the device. I only get the battery information. I have set the association. I use openhab 2.1.
Does anybody know, what I can do to solve the Problem?
normen
(Normen)
June 30, 2017, 3:41pm
2
here are the zwave log
2017-06-30 17:40:10.078 [Handler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 34 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00 26
2017-06-30 17:40:10.084 [ZWaveController ] - Receive queue TAKE: Length=0
2017-06-30 17:40:10.087 [SerialMessage ] - Assembled message buffer = 01 13 00 04 00 34 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00 26
2017-06-30 17:40:10.092 [ZWaveController ] - Process Message = 01 13 00 04 00 34 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00 26
2017-06-30 17:40:10.095 [ZWaveController ] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 34 0D 60 0D 00 00 71 05 00 00 00 FF 06 17 00
2017-06-30 17:40:10.098 [icationCommandMessageClass] - NODE 52: Application Command Request (ALIVE:DONE)
2017-06-30 17:40:10.101 [ZWaveNodeInitStageAdvancer] - NODE 52: Starting initialisation from DONE
2017-06-30 17:40:10.104 [ZWaveController ] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@ed95b0 already registered
2017-06-30 17:40:10.108 [icationCommandMessageClass] - NODE 52: Incoming command class MULTI_INSTANCE
2017-06-30 17:40:10.111 [eMultiInstanceCommandClass] - NODE 52: Received MULTI_INSTANCE command V0
2017-06-30 17:40:10.115 [eMultiInstanceCommandClass] - NODE 52: Requested Command Class = ALARM (0x71)
2017-06-30 17:40:10.117 [eMultiInstanceCommandClass] - NODE 52: Endpoint 0 not found. Cannot set command classes.
2017-06-30 17:40:10.120 [icationCommandMessageClass] - NODE 23: Transaction not completed: node address inconsistent. lastSent=23, incoming=255
normen
(Normen)
July 1, 2017, 3:42pm
3
With OH2.2 it is working except the temperature. The value for the temperature is alway 0
