Did the Z-Wave channel battery-level
change to battery_level
recently please?
(note the – and _ separator).
Given that other channel names use underscores, the change makes sense, but I’d like to understand the potential for a future config pit fall:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/openhab-2-channel-types
After experimenting with cheap 3.3v regulators to replace annoying batteries (summary: cheap = crap!), I blew up a FGK101 door sensor, and replaced it like-for-like. The old device was linked with a manual text items file, but after changing the node, the Item was never set:
Number nHall_Batt "Hall Batt [%d %%]" <battery> {channel="zwave:device:aaaaaaaa:node99:battery-level"}
I suspect adding the new device caused the binding to re-read the binding definition and change from an older battery-level to the current value of battery_level. Changing the item file to battery_level resolved the issue, but that gives a potential future trap with both battery-level and battery_level in the config.
As the pre-existing Things are already bound with Channels using the legacy binding definition, they won’t change from battery-level to battery_level.
Would deleting the Things be enough, or is Z-Wave exclusion/ inclusion needed to force a re-read of the binding definition and a change from battery-level to battery_level for all existing devices please?
I’m running a recent OH2 snapshot on a RPi2 so expect things to change as things improve step-by-step.
Thanks,
James
