Hardware: CPUArchitecture/RAM/storage PC/Core I7 being used as a server (On 24/7)/24GB Ram/500GB SSD for System/10TB Hard Drive for data (Being backed up regularly)
OS: what OS is used and which version Ubuntu 20.00 LTS
Java Runtime Environment: which java platform is used and what version Openjdk 11.0.9.1
openHAB version:3.0
Issue of the topic: please be detailed explaining your issue: Starting Openhab
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Hello All;
I have just installed openhab 3 on ubuntu 20.00 LTS. I think I installed everything correctly because I am able to type openhab-cli and I get a list of commands. However, when I type the command to start Openhab (Ie. Sudo openhab-cli start) nothing happens but I don’t get an error. I actually get another message saying that I have another instance of Openhab running so I think the start command is being executed at startup. How do I get the user interface to be displayed so I can begin exploring how to add and modify configuration files? Just for reference, I an a beginner at Ubuntu and am not a programmer by trade. However, I’d love to learn how to use the configuration files rather than the gui to challenge myself :-). Thanks. Tim
you can check if your instance is running.
If it is running you can connect to it using your browser: http://IPofOH:8080/
Things, Items that can be configured via file can be found in /etc/openhab/things resp. items.
this also can be done via the browser.
All that is described in more details at Getting Started - Introduction | openHAB and e.g. Things | openHAB
You ask about the UI to configure files. Do you want to access the above mentioned folders from another computer then you may need to make sure that Samba service is running to export these folders.
Thanks Wolfgang_S;
The systemctl status command shows that Openhab is running.
Can you tell me how to determine the IP address of Openhab ? I was thinking that information may be provided with the Systemctl command but I don’t see any IP addresses listed in it.
And yes I may need to access the above mentioned folders remotely so I will look into making sure the Samba service is running.
That’s what I’m trying to determine. Can someone tell me how to determine the IP of my server? I seem to recall I used ipconfig a while back but ubuntu doesn’t seem to recognize that this time.
As just posted you can use ifconfig from the command line to check the ip address of your server. In addition you can use ‘netstat -a’ to list all active network connections and look for a line like:
OK I got my IP from the Network settings but when I open a browser and replace the ipofoh with the ipv4 address, I get the message no such file or directory. Could I have forgotten to perform an install step or to configure my new ubuntu system properly?
I know it’s running because I get the status …
openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor prese>
Active: active (running) since Sun 2021-01-31 23:19:12 EST; 6h ago
Docs: https://www.openhab.org/docs/ https://community.openhab.org
Main PID: 3319 (java)
Tasks: 106 (limit: 38282)
Memory: 723.7M
CGroup: /system.slice/openhab.service
└─3319 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/op>
Success at last ! I used Ifconfig and got the IP and then opened a browser and entered the IP followed by :8080 and I got an Openhab login screen so I’m good now for a while until I have more questions. Hopefully I will be able to figure things out from here for a while until I need help again but it’s great you all are here. Thanks all who offered help and suggestions to get me started.
