Heal zwave device via rule or api?
Is there a way to trigger via rule a healing of a defined device?
I already searched the forum, for reinitialise I found the syntax to be send over the api, but didn’t found for healing :confused:
I see the action_heal: false on the one device I checked on both the ui code page and API. FWIW I did not see the reinitialize config?
But do you know how to send a heal via API?
I have never tried. Change to “true”?
Api UI shows error 500 :frowning:
I can get the API to accept the change (200), but it doesn’t start the heal. I just used the thing GET and copied it all to the PUT, then changed the action_heal. Tried both “true” and true. Also changed on the UI code tab with no effect, so there does seem to be a problem.
Edited order
