Would be nice if someone else using this device could share his/her experience before i start banging my head to the keyboard trying to get the channel working.
Can someone post an XML for their device - it would be nice to confirm what the device says it does ;). Once we do this we can update the database if needed.
It’s created by the binding after it’s done the device discovery.[quote=“maetz, post:5, topic:22088”]
I tried two different items:
[/quote]
Only the kwh channel is defined in the database. According to the device (ie the XML) it supports this command class - of course it’s a different question what it does or if it works. I would personally use the logfile to see what is happening.
The best place to look is when the binding is restarted since at that time the binding should try to read the value of this command class. During initialisation (DYNAMIC phase) it reads all information from the device and isn’t dependant on the definition of the channels, or items. This is probably the only (or best) place to look to see what’s happening with this.
I note that the manual doesn’t mention the METER class, but since the device says it supports it, I would have expected it to respond…
