Heater smart ui button
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage
    • OS: openhab image
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version: latest
i have a shelly 2.5 that i want to controle
I searshed for an answer but still did’net manage to find it. sorry if i missed it.
i want to create a button on UI that has 4 states :
  • on
    -off
    -eco
    -standbye
when i’m on:
“on” status i want the shelly 2.5 to switch the two alimentations on
“off” status i want the shelly 2.5 to switch the two alimentations off
“eco” status i want the shelly 2.5 to switch one alimentations off the other off
“standbye” status i want the shelly 2.5 to switch the other one alimentations off the other on
i tried many things but i don’t really know where to start.
Thanks :sunny:
Create a dummy / proxy item which has the options you want and then have that in the UI. You then create a rule that runs when your dummy / proxy item is changed where you can set the Shelly items to whatever values you want based on the new state of your dummy / proxy item.
Thanks what type name should i use, i don’t see anything like i want :
Type Name
Color
Contact
DateTime
Dimmer
Group
Location
Number
Player
Rollershutter
String
Switch
thanks again
It needs to be a string, since you have multiple states. And then you just show it on a UI as a switch or selection element with mapped buttons.
thanks ! i get it, it’s one big step for me!
