Hi all,
I am starting to implement rules to trigger heating on/off when a window will be closed/opened.
The window contact (ESP8266 based, self designed/programmed ) works through MQTT protocol
Switch Studio_Window_StudWinESP8266reed_DoorSensor "Studio Window Status [MAP(reed.map):%s]" <door> (GuestRoom, gOpenItems) ["ReedSensor"] {channel="mqtt:homie300:efd6615c:studwinesp8266reed:studWinESP8266reed#doorSensor"}
with reed.map
OFF=closed
ON=open
NULL=unknown
The corresponding thermovalve (Spirit Z-wave) has an item to control the heat mode
Number Studio_ZWaveThermoValve_ThermostatMode "Guest Room Thermovalve Mode [%.1f]" <temperature> (GuestRoom, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node2:thermostat_mode"}
Both the status of the door sensor and the manual setting of the thermovalve work perfectly.
Now the rule (far from being elegant, but I want a first working set before going for bells and whistles - suggestions welcome!)
rule "A door sensor has been triggered"
Member of gOpenItems changed
val String ruleIdentifier = "Setting Thermovalve"
val window = triggeringItem
logInfo(ruleIdentifier, "{} has triggered the event!", window.name)
val roomName = window.name.split("_").get(0)
val thermoValveName = roomName+"_ZWaveThermoValve_ThermostatMode"
val windowState = if(window.state == ON) "open" else "close"
val setValue = if(window.state == ON) 0 else 1
logInfo(ruleIdentifier, "{} has just {}! Setting {} to {}", roomName, windowState, thermoValveName, setValue)
thermoValveName.sendCommand(setValue)
The rule does not work, and the error message is
2020-03-20 23:46:32.737 [INFO ] [ome.model.script.Setting Thermovalve] - Studio_Window_StudWinESP8266reed_DoorSensor has triggered the event!
2020-03-20 23:46:32.750 [INFO ] [ome.model.script.Setting Thermovalve] - Studio has just open! Setting Studio_ZWaveThermoValve_ThermostatMode to 0
2020-03-20 23:46:32.753 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'A door sensor has been triggered': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(java.lang.String,java.lang.String) on instance: null
If I replace the line
with the explicit Item name (I have only one thermovalve for testing purposes)
Studio_ZWaveThermoValve_ThermostatMode.sendCommand(setValue)
everything works
2020-03-20 23:50:32.291 [INFO ] [ome.model.script.Setting Thermovalve] - Studio_Window_StudWinESP8266reed_DoorSensor has triggered the event!
2020-03-20 23:50:32.302 [INFO ] [ome.model.script.Setting Thermovalve] - Studio has just close! Setting Studio_ZWaveThermoValve_ThermostatMode to 1
2020-03-20 23:50:32.336 [ome.event.ItemCommandEvent] - Item 'Studio_ZWaveThermoValve_ThermostatMode' received command 1
2020-03-20 23:50:32.340 [nt.ItemStatePredictedEvent] - Studio_ZWaveThermoValve_ThermostatMode predicted to become 1
Could you help me with this? And generally, where is there any comprehensive doc (other than this) to understand how to write rules? I have past experience in more “conventional” programming languages (C, C++, Python), is Jython perhaps a valid alternative?
Thanks!
Max
