Hey guys,
after two days of brainstorming and setting up rules like this and that and so, I need your advice.
What I’m trying is to define a rule, which controls my heating depending on the following basic information:
set temp to 22°C between 6 and 8 am or 5 and 7pm but set this in dependence of the outside temperature
May last try is like that:
var Number hour_Bath = now.getHourOfDay
rule “Test Rule2”
//Item Temperature received update or
//Item Date received update or
Time cron “0 0 * * * ?” or
System started
logInfo(“Test Rule2”,“Start Test Rule2”)
if((Temperature.state as Number) <= 14){
if((hour_Bath >= 17 && hour_Bath <= 19) || (hour_Bath >= 6 && hour_Bath <= 8)){
var heat=22.0
logInfo("Test Rule2", "Die Heizung im Bad wird auf "+heat + "°C gestellt.")
sendNotification("notificationaddress", "Die Heizung im Bad wird auf "+heat + "°C gestellt.")
Bath_Control_Mode.sendCommand(heat)
else{
var heat=4.5
logInfo("Test Rule2", "Außerhalb der Heizzeiten, wird die Heizung deaktiviert.")
sendNotification("notificationaddress", "Außerhalb der Heizzeiten, wird die Heizung deaktiviert.")
else if((Temperature.state as Number) >= 14.01){
logInfo("Test Rule2", "Es ist wärmer als 14°C. Die Heizung wird trotz Heizzeit nicht aktiviert.")
sendNotification("notificationaddress", "Es ist wärmer als 14°C. Die Heizung wird trotz Heizzeit nicht aktiviert.")
What I figured out is that the rule will fire an info to log after “system started”. But not between 6 and 8pm or 5 and 7pm.
If I tried to set the rule in the “when” part like this:
The rule will fire an logentry every update of item Temperature.
Is there a better way to get this rule running with my basic conditions? And do you think that the if conditions with the timeframes are correct?
The hour_Bath variable is outside of the rule. It will be set when the rule file is loaded and never change. If you move it into your rule, it will update every time the rule runs.
You are also checking the times twice. Instead, just check the time once and move the temp check inside. You also don’t need the ‘else if’… is the temp is not <= 14, then it is > 14, so you can just use an else.
Thanks both for your help. I have done some improvements to the rule and it works pretty well.
So but I have an additional quastion related to that rule, where I stuck.
I have changed my rule to the following:
rule "Test Rule1"
//Time cron "0 0 * * * ?" or
System started
var heat=22.0
var heat_setback=4.50
if(((hour_Bath >= 17) && (hour_Bath < 19)) || ((hour_Bath >= 6) && (hour_Bath < 8))){
//var heat=22.0
if (Bath_Control_Mode.state != heat){
//var heat=22.0
logInfo("Test Rule1", "Bad: Die Heizung im Bad wird auf "+heat + "°C gestellt.")
//logInfo("Test Rule1", "Changing mode to " + heat.toString)
else{
loginfo("Test Rule1", "Bad: Die Heizung ist bereits auf "+heat + "°C gestellt.")
else{
logInfo("Test Rule1", "Bad: Es ist wärmer als 14°C. Die Heizung wird trotz Heizzeit nicht aktiviert.")
logInfo("Test Rule1", "Bad: Die Heizung ist auf "+Bath_Control_Mode +"°C gestellt.")
else{
logInfo("Test Rule1", "Bad: Außerhalb der Heizzeiten, wird die Heizung deaktiviert.")
//sendNotification("notificationaddress", "Bad: Außerhalb der Heizzeiten, wird die Heizung deaktiviert.")
Bath_Control_Mode.sendCommand(heat_setback)
So, what I’m looking now is an additional “if” or “else if” to check during second and third “else” if “Bath_Control_Mode” = heat_setback, and if not, set it to heat_setback.
What do you think or where do you think, does I have do change/adopt my rule?
Not sure what you are trying to do exactly, you might find “else if” construction useful?
if (condition X) {
// do this
} else if (condition Y) {
// do that
} else {
// neither X nor Y were true
// do something else
// only one of three sections will be executed
