Hello Heiko,
even if there are no changes since the first post (I think), here again the Yaml-Code of the widget:
Yaml-Code:
uid: Heating-Control_1-8-1_v5
tags:
- 1 Window-Sensor (Contact OPEN/CLOSED no AJAR)
- 2 Battery-Items (Switch ON/OFF) for Window and Thermostat
- 4 visible Corner Items - more Infos
- Background - Multicolor - Fantasy-Colors
- ON/OFF Switch
- Original from Nico Version V.1.8.1
- Pimps from Peter
- Thermostat-Widget
- flexible Corners
- https://community.openhab.org/t/heating-widget/115107
props:
parameters:
- description: eg. living room
label: location and widget identifier
required: true
type: TEXT
- default: "350"
description: Visual size of the control in px (default 350px), without a size
the design is responsive
label: size [px]
required: false
type: TEXT
- description: Minimum value
label: minTemp
required: true
type: TEXT
- description: Maximum value
label: maxTemp
required: true
- context: item
description: Item to set/control target temperatur
label: Set point Item
required: true
type: TEXT
- context: item
label: Item for current temperature
required: true
type: TEXT
- description: Control item unit eg °C
label: unit
required: false
type: TEXT
- description: URL or path to a Image (if you use a local img eg. ->
http://local-IP-Adress:8080/static/folder/img.svg )
label: URL or path to image
required: false
type: TEXT
advanced: true
- description: Device modes as array eg. MANUAL,AUTOMATIC,VACATION.
label: Device Mode Array
required: false
type: TEXT
advanced: true
- description: Heating modes of the thermostate as array eg.
ECO,COMFORT,BOOST,ON,OFF,WINDOW_OPEN.
label: Heating Mode Array
required: false
type: TEXT
advanced: true
- context: item
description: Device Mode Item [String-Item] - readonly
label: Device Mode Item
required: false
type: TEXT
advanced: true
- context: item
description: Heating Mode Item [String-Item] (eg. value of heating Item -
corresponds also with setpoint )
label: Heating Mode Item
required: false
type: TEXT
advanced: true
- context: item
description: Valve Item [Switch-Item] (eg. State of heating valve) for Animation
label: Valve Item
required: false
type: TEXT
advanced: true
- context: item
label: Item to display window state
required: false
type: TEXT
- context: item
description: Item to display low-state of the battery of the thermostat (Switch
ON/OFF)
label: Low-state thermostat-battery (Switch ON/OFF)
required: false
type: TEXT
- context: item
description: Item to display low-state of the battery of the window-sensor(s)
(Switch ON/OFF Group Item is possible)
label: Low-state window-sensor(s)-battery (Switch ON/OFF)
required: false
type: TEXT
- label: Custom font-size current&set-point marker (eg. 1em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size center (eg. 2em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size buttons (eg. 1.8em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size footer (eg. 1em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Main-Color Thermostat
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color control ring
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color buttons
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color center
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color Typo
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color setPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color currentPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient startPoint
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient endPoint
required: false
type: TEXT
groupName: colors
advanced: true
- context: item
description: Top Left Item to show Information
label: Top Left Item
required: false
type: TEXT
groupName: outeritems
advanced: true
- description: Top Left Icon to show Information
label: Top Left Icon
required: false
type: TEXT
advanced: true
- context: item
description: Top Right Item to show Information
label: Top Right Item
required: false
type: TEXT
advanced: true
- description: Top Right Icon to show Information
label: Top Right Icon
required: false
type: TEXT
advanced: true
- context: item
description: Bottom Left Item to show Information
label: Bottom Left Item
required: false
type: TEXT
advanced: true
- description: Bottom Left Icon to show Information
label: Bottom Left Icon
required: false
type: TEXT
advanced: true
- context: item
description: Bottom Right Item to show Information
label: Bottom Right Item
required: false
type: TEXT
advanced: true
- description: Bottom Right Icon to show Information
label: Bottom Right Icon
required: false
type: TEXT
advanced: true
- description: Widgetbackground e.g. "transparent" or "blue" or
"linear-gradient(to bottom right,#B0E0E6 20%,#1E90FF 30%,#FFC0CB 60%)"
label: Background
required: false
type: TEXT
groupName: layout
advanced: true
- description: Corners/Edges from top-left to bottom left e.g. 15% 5% 8% 3%
label: Corners
required: false
type: TEXT
groupName: layout
advanced: true
parameterGroups:
- name: colors
label: Color-Settings
- name: fonts
label: Font-Settings
- name: outeritems
label: Outer-Items
- name: layout
label: Widget-Layout
timestamp: Nov 5, 2024, 5:52:42 PM
component: f7-card
border: no
style:
--f7-card-box-shadow: none
--relVer: Rel_1.8.1_v5
background: '=(props.background1) ? props.background1 : "linear-gradient(122deg,
rgba(34,193,195,1) 0%, rgba(253,187,45,1) 100%)"'
background-position: down
background-repeat: no-repeat
background-size: cover
border-radius: '=(props.corners) ? props.corners : "0%"'
font-size: medium
height: auto
margin: 5px
noShadow: true
padding: 0px
width: '=(props.size) ? (props.size) * 1.23 + "px": "400px"'
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-row
class:
- justify-content-center
resizable-absolute: true
resizableFixed: true
slots:
default:
- component: f7-col
style:
align-items: flex-start
display: '=(props.item) ? "flex" : "flex"'
flex-direction: column-reverse
justify-content: flex-start
left: 10px
margin-left: 02px
margin-top: 5px
padding: 10px
position: absolute
top: 5px
z-index: 2
slots:
default:
- component: oh-icon
icon: =props.tl_icon
style:
bottom: 0%
height: "=props.size ? (Number(props.size)/10) +'px' : '65%'"
left: 0%
transform: translate(-20%,-0%)
- component: Label
style:
font-size: "=props.size ? (Number(props.size)/17) +'px' : '15px'"
text: =(items[props.tl_item].displayState) || (items[props.tl_item].state)
- component: f7-col
style:
align-items: flex-end
display: flex
justify-content: flex-end
margin-right: 5px
padding: 10px
position: absolute
right: 10px
top: 10px
z-index: 2
slots:
default:
icon: =props.tr_icon
style:
bottom: 0%
left: 0%
transform: translate(-0%,-0%)
- component: Label
style:
text: =(items[props.tr_item].displayState) || (items[props.tr_item].state)
- component: f7-row
class:
slots:
default:
- component: f7-block
class: thermostat
style:
--f7-block-margin-vertical: 0px
--f7-block-padding-horizontal: 0px
--f7-block-padding-vertical: 0px
background: "=props.colorThermostat ? props.colorThermostat :
'var(--f7-toggle-inactive-color)'"
border: 2px solid rgb(64, 60, 77)
border-radius: 50%
box-sizing: content-box
flex-shrink: 0
padding-left: 0px
padding-top: "=props.size ? props.size + 'px': '100%'"
width: "=props.size ? Number(props.size)+'px' : '100%'"
slots:
default:
class: bar
style:
border-radius: 50%
height: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
left: 50%
margin-top: 0px
position: absolute
top: 50%
transform: translate(-50%, -50%)
width: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
slots:
default:
class: inner_bar
style:
background-color: "=props.colorThermostat ? props.colorThermostat :
border-radius: 100%
height: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
left: 50%
margin-top: 0
position: absolute
top: 50%
width: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
z-index: 4 !important
slots:
default:
style:
background: "='conic-gradient(transparent 0deg 160deg, ' +
(props.colorThermostat ?
'var(--f7-toggle-inactive-color)') + '
160deg 200deg, transparent 200deg
360deg)'"
bottom: "=props.size ? '-7px' : '-7px'"
content: ""
display: block
height: 100%
left: 50%
position: absolute
transform: translate(-50%)
width: 100%
class: hold left
style:
background-color: rgb(58, 55, 73)
border-radius: 100%
clip-path: "=props.size ? 'inset(0px 0px 0px ' + (Number(props.size)*0.89/2) +
'px)' : 'inset(0% 0% 0% 50%)'"
height: 100%
margin-top: 0px
position: absolute
width: 100%
slots:
default:
class: fill fill1
style:
background: "=props.colorBarStartPoint && props.colorBarEndPoint ?
'-webkit-linear-gradient(top, ' +
props.colorBarEndPoint + ' 20%,' +
props.colorBarEndPoint + ' 100%)' :
'-webkit-linear-gradient(top, rgb(255,
73, 0) 20%,rgb(255, 73, 0) 100%)'"
border-radius: 100%
clip-path: "=props.size ? 'inset(0px ' + (Number(props.size)*0.89/2) + 'px 0px
0px)' : 'inset(0% 50% 0% 0%)'"
height: 100%
margin-top: 0px
position: absolute
transform: "=(items[props.setPointItem].state.split(' ')[0] >=
(((Number(props.maxTemp) -
Number(props.minTemp)) / 2) +
Number(props.minTemp)) &&
items[props.setPointItem].state.split\
(' ')[0] <= Number(props.maxTemp) ?
'rotate('+(320/(Number(props.maxTemp)\
-Number(props.minTemp))*(items[props.\
')[0]-Number(props.minTemp))-160)+'de\
g)' :
(items[props.setPointItem].state.spli\
t(' ')[0] > Number(props.maxTemp)) ?
'rotate(180deg)' : '')"
transition: transform 0.6s
width: 100%
z-index: 1 !important
class: hold right
style:
border-radius: 100%
height: 100%
margin-top: 0px
position: absolute
transform: rotate(180deg)
width: 100%
z-index: 3 !important
slots:
default:
class: fill
style:
animation: right 1s linear both
border-radius: 100%
height: 100%
margin-top: 0px
position: absolute
width: 100%
class: fill fill2
style:
props.colorBarEndPoint + ' 40%,' +
props.colorBarStartPoint + ' 100%)' :
73, 0) 40%,rgb(255, 158, 35) 100%)'"
border-radius: 50%
clip-path: "=props.size ? 'inset(0px '+ (Number(props.size)*0.89/2) + 'px 0px
height: 100%
margin-top: 0px
position: absolute
transform: "=(items[props.setPointItem].state.split(' ')[0] <=
(' ')[0] >= Number(props.minTemp) ?
')[0]-Number(props.minTemp))+20)+'deg\
t(' ')[0] > (((Number(props.maxTemp) -
Number(props.minTemp))) ?
width: 100%
class: span
style:
bottom: 0px
color: "=props.colorTypo ? props.colorTypo : 'rgb(87, 84, 95)'"
font-size: "=props.fontSizeFooter ? props.fontSizeFooter : '1em'"
font-weight: "=props.size ? (Number(props.size)*2) +'px' :
'calc(var(--f7-list-item-title-font-weight)\
*2)'"
margin-top: 0px
position: absolute
text-align: center
text-transform: capitalize
width: "=props.size ? (Number(props.size)*0.89) +'px' : '100%'"
z-index: 99 !important
slots:
default:
- component: Label
style:
font-size: "=props.size ? (Number(props.size)/25) +'px' : '12px'"
text: "Rel.: 1.8.1_v5"
class: shadow
style:
animation: shadow 1.4s ease-out both
height: 86%
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
Number(props.minTemp) &&
Number(props.maxTemp) ? 'translate(-50%, -50%)
rotate('+(320/(Number(props.maxTemp)-Number(props\
.minTemp))*(items[props.setPointItem].state.split\
(' ')[0]-Number(props.minTemp))-160)+'deg)' :
'translate(-50%, -50%) rotate(0deg)')"
transition: 0.7s ease
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '6.25%'"
slots:
default:
class: shadow-cube
style:
box-shadow: "=props.size ? '0 0 ' + (Number(props.size)*0.1125) +'px ' +
(Number(props.size)*0.0325) + 'px ' +
(props.colorSetMarker ? props.colorSetMarker
: 'rgba(255, 158, 35, 0.5)'): '0 0 45px 13px
rgba(255, 158, 35, 0.5)'"
height: 0px
margin-top: 0px
position: absolute
top: 0
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '100%'"
class: markerContainer
style:
height: 100%
left: 50%
margin-top: 0px
opacity: 1
pointer-events: none
position: absolute
text-align: center
top: 50%
transform: "=(items[props.currentPointItem].state.split(' ')[0] >=
<= Number(props.maxTemp) ? 'translate(-50%, -50%)
.minTemp))*(items[props.currentPointItem].state.s\
plit(' ')[0]-Number(props.minTemp))-160)+'deg)' :
width: "=props.size ? (Number(props.size)*0.1) +'px' : '10%'"
slots:
default:
class: markerCurrent
style:
background: "=props.colorCurrentMarker ? props.colorCurrentMarker : 'rgb(33,
150, 243)'"
border-radius: 0% 50% 50% 50%
box-shadow: 0 0 5px 1px rgb(48, 46, 56)
height: "=props.size ? (Number(props.size)*0.1) +'px' : ''"
left: 50%
margin-top: 0px
padding-top: "=props.size ? '' : '100%'"
position: absolute
top: "=props.size ? (Number(props.size)*0.14) +'px' : '15%'"
transform: translate(-50%,-50%) rotate(45deg)
width: "=props.size ? (Number(props.size)*0.1) +'px' : '100%'"
slots:
default:
class: number
style:
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
transform: translate(-50%, -50%) rotate(-45deg)
slots:
default:
- component: Label
style:
color: white
font-size: "=props.fontSizeMarker ? props.fontSizeMarker : '1em'"
font-weight: bold
text: =items[props.currentPointItem].state.split(' ')[0]
style:
height: 100%
left: 50%
margin-top: 0px
opacity: 1
position: absolute
text-align: center
top: 50%
slots:
default:
class: markerSet
style:
background: "=props.colorSetMarker ? props.colorSetMarker : 'rgb(230, 74, 25)'"
border-radius: 50% 50% 50% 0
left: 50%
margin-top: 0px
position: absolute
top: "=props.size ? (Number(props.size)*Number(-0.0125)) +'px': '-2%'"
transform: translate(-50%,-50%) rotate(-45deg)
z-index: 100 !important
slots:
default:
class: number
style:
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
transform: translate(-50%, -50%) rotate(45deg)
slots:
default:
- component: Label
style:
color: white
font-weight: bold
text: =items[props.setPointItem].state.split(' ')[0]
class: center
style:
background: "=props.colorControlRing ? props.colorControlRing : 'rgb(227, 228,
237)'"
border-radius: 50%
box-shadow: 0px 15px 35px 11px rgba(46, 44, 58,0.60)
height: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
left: 50%
margin-top: 0px
position: absolute
top: 50%
width: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
slots:
default:
icon: "=(items[props.batteryItem].state === 'OFF') ? 'lowbattery1-off' :
'lowbattery1-on'"
item: =props.batteryItem
style:
bottom: 32%
height: 48%
left: 76%
position: absolute
transform: translate(-55%,-48%) rotate(-140deg)
width: 15%
visible: "=props.batteryItem ? true : false"
icon: "=(items[props.batteryItem1].state === 'OFF') ? 'lowbattery1-off' :
'lowbattery1-on'"
item: =props.batteryItem1
style:
bottom: 32%
height: 48%
left: 25%
position: absolute
transform: translate(-55%,-48%) rotate(-39deg)
width: 15%
visible: "=props.batteryItem1 ? true : false"
icon: "=(items[props.windowItem].state === 'OPEN') ? 'window-open' :
'window-closed'"
style:
bottom: 40%
height: 50%
left: 50%
position: absolute
width: 20%
visible: "=props.windowItem ? true : false"
class: buttonContainer
style:
display: "=props.deviceModeItem ? '' : 'none'"
height: 100%
left: 50%
margin-top: 0px
opacity: 1
position: absolute
text-align: center
top: 50%
transform: "=props.heatingModeItem ? 'translate(-50%, -50%) rotate(40deg)' :
'translate(-50%, -50%)'"
width: "=props.size ? (Number(props.size)*0.15) +'px' : '15%'"
slots:
default:
- component: oh-button
popoverOpen: ='.' + props.location + '.popoverHeatingMode'
style:
bottom: 0%
color: "=props.colorButton ? props.colorButton + ' !important': ''"
height: 20%
left: 50%
position: absolute
width: 100%
slots:
default:
- component: f7-icon
f7: "=props.deviceModeItem ? (items[props.deviceModeItem].state
== props.deviceModeArray.split('\
,')[0] ? 'hand_raised' :
props.deviceModeArray.split(',')[\
1] ? 'arrow_2_squarepath' :
2] ? 'airplane' : 'thermometer') :
style:
font-size: "=props.fontSizeButtons ? props.fontSizeButtons : '2em'"
margin-top: auto
position: absolute
top: 50%
- component: f7-popover
class: =props.location + ' popoverHeatingMode'
slots:
default:
action: variable
actionVariable: myVar
actionVariableValue: success
class:
- popover-close
clearVariable: true
noShadow: true
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
- component: oh-repeater
containerStyle:
width: 100%
for: buttonlabel
in: =props.deviceModeArray.split(",")
slots:
default:
action: command
actionCommand: =loop.buttonlabel
actionItem: "=props.deviceModeItem ? props.deviceModeItem : ''"
active: "=props.deviceModeItem ? (items[props.deviceModeItem].state ===
loop.buttonlabel ?
true : false) : ''"
class: margin
color: "=props.colorButton ? props.colorButton : ''"
outline: true
text: =loop.buttonlabel
style:
display: "=props.heatingModeItem ? '' : 'none'"
height: 100%
left: 50%
margin-top: 0px
opacity: 1
position: absolute
text-align: center
top: 50%
transform: "=props.deviceModeItem ? 'translate(-50%, -50%) rotate(-40deg)' :
slots:
default:
popoverOpen: ='.' + props.location + '.popoverExampleMode'
style:
bottom: 0%
height: 20%
left: 50%
position: absolute
width: 100%
slots:
default:
f7: "=props.heatingModeItem ? (items[props.heatingModeItem].state
== props.heatingModeArray.split(\
',')[0] ? 'thermometer' :
props.heatingModeArray.split(',')\
[1] ? 'thermometer_sun' :
[2] ? 'rocket' :
[3] ? 'gauge' :
[4] ? 'gauge_badge_minus' :
'wrench') : ''"
style:
margin-top: auto
position: absolute
top: 50%
class: =props.location + ' popoverExampleMode'
slots:
default:
action: variable
class:
- popover-close
clearVariable: true
noShadow: true
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
containerStyle:
width: 100%
for: buttonlabel
in: =props.heatingModeArray.split(",")
slots:
default:
action: command
actionItem: "=props.heatingModeItem ? props.heatingModeItem : ''"
active: "=props.heatingModeItem ? (items[props.heatingModeItem].state ===
loop.buttonlabel ?
true : false) : ''"
class: margin
outline: true
action: command
actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) >
')[0]) - 0.5 : ''"
actionItem: =props.setPointItem
style:
height: 50%
left: 10%
margin-top: 0px
position: absolute
top: 50%
width: 30%
slots:
default:
f7: arrow_turn_left_down
style:
margin-top: auto
position: absolute
top: 50%
action: command
actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) <
')[0]) + 0.5 : ''"
style:
height: 50%
left: 90%
margin-top: 0px
position: relative
top: 50%
width: 30%
slots:
default:
f7: arrow_turn_right_up
style:
margin-top: auto
position: absolute
top: 50%
class: valveAnimation
style:
animation: skeleton-effect-fade 2s linear infinite
background: "=props.colorSetMarker ? 'radial-gradient(' + props.colorSetMarker
+' 30%, transparent 50%)' :
'radial-gradient(var(--f7-theme-color) 30%,
transparent 50%)'"
border-radius: 50%
display: "=(props.valveItem && items[props.valveItem].state == 'ON' )? '' :
'none'"
height: 100%
left: 50%
margin-top: 0px
position: absolute
top: 50%
width: 100%
z-index: -100 !important
class: small
style:
animation: bound-in-small 0.6s ease forwards
background: "=props.colorCenter ? props.colorCenter : 'rgb(248, 249, 250)'"
border-radius: 50%
box-shadow: 0px 5px 10px 5px rgba(96, 93, 111,0.19)
height: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
width: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
slots:
default:
class: heat
style:
font-size: "=props.size ? (Number(props.size)*0.0375) +'px' : '14px'"
font-weight: 300
slots:
default:
- component: Label
text: =props.location
class: heat
style:
font-size: "=props.fontSizeCenter ? props.fontSizeCenter : '2em'"
font-weight: 300
slots:
default:
- component: Label
text: "=props.unit ? items[props.setPointItem].state.split(' ')[0] + '' +
props.unit :
items[props.setPointItem].state.s\
plit(' ')[0]"
- component: oh-image
style:
left: 50%
position: absolute
width: 40%
url: "=props.imgUrl ? props.imgUrl :
'https://community-openhab-org.s3-eu-centra\
l-1.amazonaws.com/original/2X/7/7d388a8\
6c95471f89b1bb911d96d7609a3e3a059.svg'"
f7: power
style:
bottom: -30%
color: '=(items[props.valveItem].state == "OFF") ? props.colorButton : "red"'
left: 50%
position: absolute
width: 40%
visible: "=props.valveItem ? true : false"
action: command
actionCommand: '=(props.valveItem && items[props.valveItem].state == "OFF") ?
"ON" : "OFF"'
actionItem: =props.valveItem
style:
--f7-button-fill-hover-bg-color: transparent
--f7-button-hover-bg-color: transparent
bottom: -30%
left: 50%
position: absolute
width: 40%
- component: f7-row
style:
color: '=(props.textcolor1) ? props.textcolor1 : "darkgreen"'
display: true
font-size: 10px
height: 5px
slots:
default:
- component: f7-col
style:
bottom: 5px
display: flex
left: 5px
margin-left: 10px
padding: 10px
position: absolute
z-index: 2
slots:
default:
icon: =props.bl_icon
style:
bottom: 0%
left: 0%
- component: Label
style:
text: =(items[props.bl_item].displayState) || (items[props.bl_item].state)
- component: f7-col
style:
bottom: 5px
display: flex
margin-right: 10px
padding: 10px
position: absolute
right: 5px
z-index: 2
slots:
default:
icon: =props.br_icon
style:
bottom: 0%
left: 0%
- component: Label
style:
text: =(items[props.br_item].displayState) || (items[props.br_item].state)
and the Yaml-Code of the Configuration-SetUp for 1 Widget (Büro) as there are a lot of Parameters
Configuration-Yaml:
component: widget:Heating-Control_1-8-1_v5
background1: linear-gradient(122deg, rgba(34,193,195,1) 0%, rgba(253,187,45,1) 100%)
batteryItem: radiator_valve_01_Battery
batteryItem1: gBaWiBu
bl_icon: pressure
bl_item: aqtherm_01_pressure
br_icon: carbondioxide
br_item: esp32v3_02_smoke1
colorBarEndPoint: darkorange
colorBarStartPoint: yellow
colorButton: teal
colorCenter: lightcyan
colorControlRing: powderblue
colorCurrentMarker: lightseegreen
colorSetMarker: salmon
colorThermostat: lightblue
colorTypo: green
corners: 5% 15% 0%
currentPointItem: radiator_valve_01_Temp
deviceModeArray: MANUAL,AUTOMATIC,VACATION
deviceModeItem: radiator_valve_01_ModeX
fontSizeButtons: 1.5em
fontSizeCenter: 1.5em
fontSizeFooter: 0.6em
fontSizeMarker: 0.9em
heatingModeArray: ECO,COMFORT,BOOST,ON,OFF,WINDOW_OPEN
heatingModeItem: radiator_valve_01_Mode
imgUrl: /static/picture/OpenHAB_logo_2.svg
maxTemp: "30"
minTemp: "6"
setPointItem: radiator_valve_01_Set
tl_icon: snzb02
tl_item: aqtherm_01_temperature
tr_icon: humidity
tr_item: aqtherm_01_humidity
unit: °C
windowItem: gWindowOffice
My actual OH-Release is 4.3.3. The Widget is based/forked of the Custom-Version 1.8.1
If there are further questions, feel free to ask.
Cheers, Peter
