Running Openhab 3.0 and wanted to add a new zwave device.
I can get the scene numbers when i push the buttons. But the linked dimmer items never get a new value. When i turn on debug it seems that if you long press one of the 4 channels on buttons it always gets the value of 0?
It’s this device: OpenSmartHouse Z-Wave Device Database
2021-01-31 17:00:12.970 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@497eeac2.
2021-01-31 17:00:34.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 06 26 04 38 00 04 00
2021-01-31 17:00:34.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 06 26 04 38 00 04 00
2021-01-31 17:00:34.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Application Command Request (ALIVE:DONE)
2021-01-31 17:00:34.650 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: resetResendCount initComplete=true isDead=false
2021-01-31 17:00:34.651 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2021-01-31 17:00:34.651 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: SECURITY not supported
2021-01-31 17:00:34.651 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 46: Received COMMAND_CLASS_SWITCH_MULTILEVEL V0 SWITCH_MULTILEVEL_START_LEVEL_CHANGE
2021-01-31 17:00:34.651 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 46: Switch Multi Level start level change, direction = INCREASE
2021-01-31 17:00:34.651 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got an event from Z-Wave network: ZWaveStartStopEvent
2021-01-31 17:00:34.651 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=INCREASE
2021-01-31 17:00:34.651 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Commands processed 1.
2021-01-31 17:00:34.652 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2d767c5b.
2021-01-31 17:00:34.714 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 05 5B 03 33 82 07
2021-01-31 17:00:34.714 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 05 5B 03 33 82 07
2021-01-31 17:00:34.715 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Application Command Request (ALIVE:DONE)
2021-01-31 17:00:34.715 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: resetResendCount initComplete=true isDead=false
2021-01-31 17:00:34.715 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2021-01-31 17:00:34.715 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: SECURITY not supported
2021-01-31 17:00:34.715 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 46: Received COMMAND_CLASS_CENTRAL_SCENE V3 CENTRAL_SCENE_NOTIFICATION
2021-01-31 17:00:34.715 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 46: Received scene 7 at key 2 [Key Held Down]
2021-01-31 17:00:34.715 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-01-31 17:00:34.716 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CENTRAL_SCENE, value=7.2
2021-01-31 17:00:34.716 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Updating channel state zwave:device:749fd76572:node46:scene_number to 7.2 [DecimalType]
2021-01-31 17:00:34.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Commands processed 1.
2021-01-31 17:00:34.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2ad3ba6c.
2021-01-31 17:00:36.481 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 02 26 05
2021-01-31 17:00:36.481 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 02 26 05
2021-01-31 17:00:36.482 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Application Command Request (ALIVE:DONE)
2021-01-31 17:00:36.482 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: resetResendCount initComplete=true isDead=false
2021-01-31 17:00:36.482 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2021-01-31 17:00:36.482 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: SECURITY not supported
2021-01-31 17:00:36.482 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 46: Received COMMAND_CLASS_SWITCH_MULTILEVEL V0 SWITCH_MULTILEVEL_STOP_LEVEL_CHANGE
2021-01-31 17:00:36.482 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 46: Switch Multi Level stop level change
2021-01-31 17:00:36.482 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got an event from Z-Wave network: ZWaveStartStopEvent
2021-01-31 17:00:36.483 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=STOP
2021-01-31 17:00:36.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Commands processed 1.
2021-01-31 17:00:36.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6991b0c1.
2021-01-31 17:00:36.545 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 05 5B 03 34 81 07
2021-01-31 17:00:36.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=46, callback=0, payload=00 2E 05 5B 03 34 81 07
2021-01-31 17:00:36.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-01-31 17:00:36.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Application Command Request (ALIVE:DONE)
2021-01-31 17:00:36.546 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: resetResendCount initComplete=true isDead=false
2021-01-31 17:00:36.546 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2021-01-31 17:00:36.546 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 46: SECURITY not supported
2021-01-31 17:00:36.546 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 46: Received COMMAND_CLASS_CENTRAL_SCENE V3 CENTRAL_SCENE_NOTIFICATION
2021-01-31 17:00:36.547 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 46: Received scene 7 at key 1 [Key Released]
2021-01-31 17:00:36.547 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-01-31 17:00:36.547 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CENTRAL_SCENE, value=7.1
2021-01-31 17:00:36.547 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 46: Updating channel state zwave:device:749fd76572:node46:scene_number to 7.1 [DecimalType]
2021-01-31 17:00:36.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Commands processed 1.
2021-01-31 17:00:36.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 46: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@57877fcb.
