Then created the easy controls binding.
Nothing to set up here.
I do not reveice any values.
a) Log-Viewer does not state any errors.
b) all bindings are online (green)
c) Helios KWL EC 370 W with Modbus activated.
Any suggestiions on deep diving to an error statement?
Just got a message in logviewer:
[s.internal.HeliosEasyControlsHandler] - HeliosEasyControlsHandler encountered Exception when trying to read variable refNo from the device: null
You also have to configure at least the KWL’s IP address for the HeliosEasyControl binding (without a protocol).
You could also try to configure your Bridge and Thing based on a text file, following the documentation here: Helios easyControls - Bindings | openHAB
Hello Bernhard,
I want to read the internal humidity sensor.
I got the variable from Helios. (ASCII v02136 = variable internal FF). This is not implemented in the binding.
Is it possible to display this anyway?
Thank you
greetings D
yes, this variable doesn’t show up in Helios’ original Modbus specification.
But adding variables to the binding is relatively easy.
Please find a snapshot build including the additional variable here: GitHub - bern77/tmp
I don’t think my KWL has such a sensor, at least I only receive 0 as the corresponding value, so I can’t really test it properly - but at least I seem to get a response via the Modbus.
I also just guessed the variable’s parameters (copied from external humidity sensors).
Please test if this works for you. I’m happy to include this (or additional variables if it makes sense) in the next release.
Hello Bernard,
thank you for sending it. Maybe I did something wrong, but I can’t find the channel. I uninstalled the binding and added your file to Addons. After the restart everything works as before. What is the name of the new channel?
