Help build binding for Paradox Alarm Panel with IP150
Hi
Sorry I’ve been a bit quiet of late, very busy at work. Since the last update to the Android app I’ve been able to get the EVO’s bypass and PGM (1->5) to work. The app now basically uses the http port for bulk of its data and then the software port just to do the PGM and bypass. My plan is to make a new rev 3 of the code, which might then work for ‘all’ alarms. The software port functions will only be active when needed, so as to allow others apps to still connect (e.g. iParadox). The http port can also force-ably be logged out by a 3rd party so I will exploit that with a timer to make space for others apps (like Alarmin) to temporarily connect.
When I will have time is the question. The majority code already exist in the android app, but is in Nodejs/javascript. I will like use that for rev3, which I tend to prefer above python these days. Gimme a month, I’ll see if I can get it done by then.
regards
