Hi running OH on Proxmox … all worked great
but now OH 8080 port looks like its stuck …
from time to time i am able to reach it…
but most of the time its hanging and not giving any commands to the system
when i look at the log:tail
i see no errors !
where can i find errors for startup/web concoction
how can i check if have another app on port 8080
i did not install anything , wired thing it comes and goes …
and not always an issue ,there must be some log with that issue
log:tail only shows the last entries in the log file. Better to open openhab.log and maybe also events.log in an editor/viewer and search for ‘warning’ or ‘error’.
It sounds like your Pi is choking on something, like a rogue process consuming all CPU or memory,
Are you sure o_O 8080 is the default port for http openHAB and 8443 is https openHAB
On Linux it would be
sudo netstat -tulpen
On Windows it would be
netstan -an
and then you can see which ports are used,
Windows also has the Resource Monitor where you can Click a process and inspect the Network, which also tells you the Ports and if the ports are allowed in the Firewall.
There is also another User with this kind of issue (but with whole system crashes)
If this appears more often the might be something else wrong here.
What the…?
Quick shot, http is plain text, unencrypted and https is encrypted.
You should know about this… Since entering password on http will display you a WARNING THIS SITE IS NOT SECURE message.
The only work I see is updating the URL and maybe accepting the self signed cert from openHAB, but I dont know about your IOS Workflow App, is this something you coded yourself?
