I have openhab-alexa v3 is running and would like to take advantage of the v3 syntax. I’ve read through the Usage documentation found here: https://github.com/openhab/openhab-alexa/blob/v3/USAGE.md but can’t find anywhere in the documentation where or how to include the item channel.
For example, how would these be defined using v3 syntax:
Group Fan "Fan" {alexa="Endpoint.Other"}
Number Speed "Speed" (Fan) {alexa="RangeController.rangeValue" [supportedRange="1:10:1",presets="1=@Value.Minimum:@Value.Low:Lowest,10=@Value.Maximum:@Value.High:Highest",friendlyNames="@Setting.FanSpeed,Speed"]}
Switch Power "Power" (Fan) {alexa="ToggleController.toggleState" [friendlyNames="@DeviceName.Fan"]}
