Hello everyone. I need help restoring the functionality of an old OH 1.x version. Let me explain better: this instance is running on a home automation hardware that acts as an MQTT Gateway for a HomePLC.
The MQTT v1 add-on and HomePLC add-on are installed. Simply through the MQTT event bus, items that change value are reported in MQTT messages.
To date, I see the MQTT connection to the broker active, but no messages are coming through. OH is running automatically through the rcK and rcS scripts, and with a ‘top’ command, I think OH is running.
The issue arose when I changed the broker, and if I relaunch OH with ./start.sh, it seems that the messages start arriving on the broker…
Can anyone help me debug this issue?
Thank you.
Flavio
