milo
(M)
1
I understand that i can use the new introduced profiles as a kind of masterswitch for different single items.
I have currently following rule in my setup
rule "set hue group2 onoff"
Item switch_hueonoffgroup2 changed
if (switch_hueonoffgroup2.state == OFF) {
sendCommand(Hue_switch_colorlamp1, OFF)
sendCommand(Hue_switch_colorlamp2, OFF)
sendCommand(Hue_switch_colorlamp3, OFF)
createTimer(now.plusSeconds(40), [ | sendCommand(Hue_switch_colorlamp1, OFF) ])
createTimer(now.plusSeconds(40), [ | sendCommand(Hue_switch_colorlamp2, OFF) ])
createTimer(now.plusSeconds(40), [ | sendCommand(Hue_switch_colorlamp3, OFF) ])
}else {
sendCommand(Hue_switch_colorlamp1, ON)
sendCommand(Hue_switch_colorlamp2, ON)
sendCommand(Hue_switch_colorlamp3, ON)
createTimer(now.plusSeconds(40), [ | sendCommand(Hue_switch_colorlamp1, ON) ])
createTimer(now.plusSeconds(40), [ | sendCommand(Hue_switch_colorlamp2, ON) ])
createTimer(now.plusSeconds(40), [ | sendCommand(Hue_switch_colorlamp3, ON) ])
logInfo("set hue group2 onoff", switch_hueonoffgroup2.state.toString)
Can I exchange this rule with a profile and how???
vzorglub
(Vincent Regaud)
2
First you could create a group containing these three items then your rulle would much simpler:
if (switch_hueonoffgroupColor2.state == OFF) {
LightsGroup2.sendCommand(OFF)
createTimer(now.plusSeconds(40), [ | LightsGroup2Switch.sendCommand(OFF) ])
}else {
LightsGroup2.sendCommand(ON)
createTimer(now.plusSeconds(40), [ | LightsGroup2Switch.sendCommand(ON) ])
Or even simpler:
if (switch_hueonoffgroup2 == NULL || switch_hueonoffgroup2 == UNDEF) return; //DO NOTHING
LightsGroup2.sendCommand(switch_hueonoffgroup2.state.toString)
createTimer(now.plusSeconds(40), [ | LightsGroup2Switch.sendCommand(switch_hueonoffgroup2.state.toString) ])
For profile, we would need your item definitions, please
milo
(M)
3
Items
Switch Hue_switch_colorlamp1 "colorlamp1 Schalter" (group_house_switch_light){ channel="hue:0210:00178821b3ed:1:color" }
Switch Hue_switch_colorlamp2 "colorlamp2 Schalter" (group_house_switch_light){ channel="hue:0210:00178821b3ed:2:color" }
Switch Hue_switch_colorlamp3 "colorlamp3 Schalter" (group_house_switch_light){ channel="hue:0210:00178821b3ed:3:color" }
Switch switch_hueonoffgroup2 "Hue onoff Group2" <switch>
vzorglub
(Vincent Regaud)
4
Have you tried this:
Switch Hue_switch_colorlamp1 "colorlamp1 Schalter" (group_house_switch_light){ channel="hue:0210:00178821b3ed:1:color" [profile="follow", item="switch_hueonoffgroup2" }
I don’t know if it will work.
You can achieve the same thing with groups and no rule:
Group:Switch switch_hueonoffgroup2 "Hue onoff Group2" <switch>
Switch Hue_switch_colorlamp1 "colorlamp1 Schalter" (group_house_switch_light, switch_hueonoffgroup2){ channel="hue:0210:00178821b3ed:1:color" }
Switch Hue_switch_colorlamp2 "colorlamp2 Schalter" (group_house_switch_light, switch_hueonoffgroup2){ channel="hue:0210:00178821b3ed:2:color" }
Switch Hue_switch_colorlamp3 "colorlamp3 Schalter" (group_house_switch_light, switch_hueonoffgroup2){ channel="hue:0210:00178821b3ed:3:color" }
milo
(M)
7
No worries You help me a lot…
If I want your shortened rule
How do I need to set the items right?
vzorglub
(Vincent Regaud)
8
You need to set the items this way:
And then the rule is even simpler:
createTimer(now.plusSeconds(40), [ | switch_hueonoffgroup2.sendCommand(switch_hueonoffgroup2.state.toString) ])
But why are you sending the same command to the same items 40s later?
