Now Running openHAB 3.1.0 Release Build
Raspberry Pi 4
I was been running the 3.0.4M build …
I was working on installing a binding (SmartThings) and was following a thread to resolve various issues … now suddenly the log is stopped/stuck. I’m not sure what I could have done to break it …
Attempting to resolve I: uninstalled the Binding and have rebooted, updated but the same log message is there (this was the last log posted) … the system seems to otherwise be working fine. Automation scripts are loading, lights are working etc.
Here is the last log message (Although probably not related since I since uninstalled it):
2021-07-22 13:49:41.164 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.smartthings-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.smartthings [94]
Unresolved requirement: Import-Package: org.openhab.core.config.core
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:440) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.8]
Here are the Karaf logging levels … they seems fine:
Logger │ Level
ROOT │ WARN
com.zsmartsystems.zigbee │ WARN
javax.jmdns │ ERROR
javax.mail │ ERROR
jsr223 │ DEBUG
openhab.event │ INFO
openhab.event.AddonEvent │ ERROR
openhab.event.InboxUpdatedEvent │ ERROR
openhab.event.ItemAddedEvent │ ERROR
openhab.event.ItemChannelLinkAddedEvent │ ERROR
openhab.event.ItemChannelLinkRemovedEvent │ ERROR
openhab.event.ItemRemovedEvent │ ERROR
openhab.event.ItemStateEvent │ ERROR
openhab.event.RuleAddedEvent │ ERROR
openhab.event.RuleRemovedEvent │ ERROR
openhab.event.RuleStatusInfoEvent │ ERROR
openhab.event.StartlevelEvent │ ERROR
openhab.event.ThingAddedEvent │ ERROR
openhab.event.ThingRemovedEvent │ ERROR
openhab.event.ThingStatusInfoEvent │ ERROR
openhab.event.ThingUpdatedEvent │ ERROR
org.apache.cxf.jaxrs.sse.SseEventSinkImpl │ ERROR
org.apache.karaf.jaas.modules.audit │ INFO
org.apache.karaf.kar.internal.KarServiceImpl │ ERROR
org.apache.karaf.shell.ssh.SshUtils │ ERROR
org.apache.karaf.shell.support │ OFF
org.apache.sshd │ WARN
org.eclipse.lsp4j │ OFF
org.eclipse.smarthome.model.script │ DEBUG
org.jupnp │ ERROR
org.openhab │ INFO
org.openhab.binding.hue │ WARN
org.openhab.binding.zigbee │ WARN
org.openhab.binding.zwave │ WARN
org.openhab.core.automation │ WARN
org.openhab.core.model.script.Hall_Bath │ INFO
org.openhab.core.model.script.TimerDemo │ INFO
org.openhab.core.model.script.kitchen │ INFO
org.ops4j.pax.url.mvn.internal.AetherBasedResolver │ ERROR
org.ops4j.pax.web.pax-web-runtime │ OFF
su.litvak.chromecast.api.v2.Channel │ ERROR
I just noticed I inadvertently upgraded to release build 3.1.0 … I was using the 3.0.4M.
No, logging isn’t paused. i see the exact same text in: /var/log/openhab/openhab.log
Any ideas what I can try to resolve?
