Okay I suspect my main issue is that I’m not yet fully understanding how Things, Channels and Items work in OH2 after having spent so long with OH1.
This is what the content of my dscalarm.thing file looks like. I copied this from the documentation example and apart from the ipaddress and password, the only other thing I really changed was “MyBridgeName” and replaced it with DSCEnvisalink as shown below.
Bridge dscalarm:envisalink:DSCEnvisalink [ ipAddress=“192.168.1.96”,password=“xxxxx” ]
Thing panel panel
Thing partition partition1 [ partitionNumber=1 ]
Thing zone zone1 [ partitionNumber=1, zoneNumber=1 ]
Thing zone zone3 [ partitionNumber=1, zoneNumber=3 ]
Thing keypad keypad
An example of one of my items is then this. I also copied this from the example and mainly just replaced the MyBridgeName with DSCEnvisalink again.
Number PARTITION1_ARM_MODE “Partition 1 Arm Mode: [%d]” (DSCAlarmPartitions) {channel=“dscalarm:partition:DSCEnvisalink:partition1:partition_arm_mode”}
But I must be doing something wrong because I get this kind of thing in the log files…
[WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command ‘1’ for item ‘PARTITION1_ARM_MODE’ to handler for channel ‘dscalarm:partition:DSCEnvisalink:partition1:partition_arm_mode’, because no thing with the UID ‘dscalarm:partition:DSCEnvisalink:partition1’ could be found.
I apologise because there are probably a million questions on things, channels and items… But if anyone could help me understand what I’m doing wrong then a light bulb might go off in my head and I’ll finally understand how everything should now be setup.
