Hi Guys ,
Im a beginner , i have project for temperature Sensors (5 Sensors) . I want to store like every temperature for every sensor , i use MySQL for databases . The problem is , I tried to add a chart for each sensor and failed to do that. How can i modify the file “mysql.persist” to stock each data in a different database ? How can I show the chart in the same frame as the temperature ?
Here is the code for the sitemap :
sitemap home label=“Reseau Des Capteurs”
Frame label=“Liste des noeuds”{
Group item=Temperature_Sensor1
Group item=Temperature_Sensor2
Group item=Temperature_Sensor3
Group item=Temperature_Sensor4
Group item=Temperature_Sensor5
Here is the code for the items;
/declaration menu 1/
Group Temperature_Sensor1 “Noeud 1”
Group Temperature_Sensor2 “Noeud 2”
Group Temperature_Sensor3 “Noeud 3”
Group Temperature_Sensor4 “Noeud 4”
Group Temperature_Sensor5 “Noeud 5”
/declaration menu 2/
Group TS1 “Capteur 1” (Temperature_Sensor1)
Group TS2 “Capteur 2” (Temperature_Sensor2)
Group TS3 “Capteur 3” (Temperature_Sensor3)
Group TS4 “Capteur 4” (Temperature_Sensor4)
Group TS5 “Capteur 5” (Temperature_Sensor5)
/Declaration items Temperature(Number) et Graphe(Chart)********/
/1/
Number Node1 “Temperature capteur 1 [%.1f °C]” (TS1) {mqtt="<[mymosquitto:local/sensor/1:state:default]"} /Topic : local/sensor/1/
Chart item=Node1 period=h refresh=100 (TS1)
/2/
Number Node2 “Temperature capteur 2 [%.1f °C]” (TS2) {mqtt="<[mymosquitto:local/sensor/2:state:default]"} /Topic : local/sensor/2/
/Chart item=Node2 period=4h refresh=100 (Temperature_Sensor2)/
/3/
Number Node3 “Temperature capteur 3 [%.1f °C]” (TS3) {mqtt="<[mymosquitto:local/sensor/3:state:default]"} /Topic : local/sensor/3/
/Chart item=Node3 period=4h refresh=10 (Temperature_Sensor3)/
/4/
Number Node4 “Temperature capteur 4 [%.1f °C]” (TS4) {mqtt="<[mymosquitto:local/sensor/4:state:default]"} /Topic : local/sensor/4/
/Chart item=Node4 period=4h refresh=10000 (Temperature_Sensor4)/
/5/
Number Node5 “Temperature capteur 5 [%.1f °C]” (TS5) {mqtt="<[mymosquitto:local/sensor/5:state:default]"} /Topic : local/sensor/5/
/Chart item=Node5 period=4h refresh=10000 (Temperature_Sensor5)/
Here is the mysqlpersist file :
Strategies {
default = everyChange
Items {
* : strategy = default, restoreOnStartup
Thanks !
