I created a rule when I get home then the blinds open
My question is how can it be done that after a certain hour the lights will turn on and not at a specific time
Thanks in advance
Start by posting your rule and showing us what you’ve tried.
At a high level, when the rule triggers, check to see what time it is and if it’s the right time run, otherwise return.
this is the rule:
rule "raz at home"
Item razAtHome changed to ON
if (sapirAtHome.state==OFF)
shelly_shelly25_roller_68c63afb13b6_roller_rollerpos.sendCommand(100)
shelly_shelly25_roller_483fda4ce5bb_roller_rollerpos.sendCommand(100)
shelly_shelly25_roller_10521cf9964f_roller_rollerpos.sendCommand(100)
shelly_shelly25_roller_68c63af93058_roller_rollerpos.sendCommand(71)
shelly_shelly25_roller_68c63afb0e45_roller_rollerpos.sendCommand(53)
shelly_shelly25_roller_68c63afb1a9c_roller_rollerpos.sendCommand(100)
shelly_shelly1_f4cfa27683a2_relay_output.sendCommand(ON)
And I want when I arrive after 6pm then the light will turn on:
Perhaps add an if statement like this…
if (now.getHourOfDay() >= 18)
Mike
Why not work for me?
the item razAtHome not change to OFF when i try this rule:
(for test i have fake GPS app on my android)
rule "raz at home"
I think you need some extra curly brackets:
rule "raz at home"
if (sapirAtHome.state==OFF){
if (now.getHourOfDay() >= 18) {
Your rule would start when the item razAtHome
changes to ON, in the rule there is no code that would switch this item to OFF.
thanks, it work
