openhab 2.5 i think.
big issues
connected via ssh.
did a sudo openhabian-config
first i choose “upgrade system”.
This did not do a lot, i then took “Install openhab” - install or upgrade to openenhab release 3.
it told me i was in a “master” which was version 2.5 stable or so, the only other options were older versions + openhab3, i took the option that said “recomended”. -> behind version 3
i received operation succesful.
and i whent back to the command window to restart my service with sudo service openhab2 restart:
"failed to restart openhab2.service: unit openhab2.service not found.
Changed the 2 to a 3 , but this had the same issue.
When reconnecting via ssh i see in the command prompt still the:
also restarted the rpi.
am i doing something wrong pls?
i can not connect to my device homepage anymore, theandroid app is also not connected anymore.
Upps. I did a few typos in my list of questions. Will correct that.
What I already can say is that you need to make sure that Java 11 is installed. You have java 8.
Errors in above list of commands should be corrected now.
What I see is that OH3 is installed that is ok.
Please run the systemctl command for openhab service.
Use openhabian-config to install java 11 ( zulu ).
Errors are logged in file /var/log/openhab/openhab.log.
As you use the windows share you need to make sure that this also works on the right directory ( /var/log/openhab and not /var/log/openhab2 ).
indeed “sudo systemctl status openhab” shows as active (running) -> should be visible in my screenshot abbove.
If that was what you mean.
it did not ask me to fix autostart.
And what do you want me to choose in my branch?
update: after installing zulu… i notice my hadbpanel was doing something, so i tried the website of my device.
It works!
i have 3 questions:
It does ask me to make a new admin account and pw, is this needed? (i feel this is going to be an empty openhab - habpanel is kind a broken it seems on the tablet)
now all this works… do i still need to do the sudo systemctl daemon-reload ?
