Help, I'm ready to give up
I don’t want to kidnap the thread ( to much :slight_smile: )
this thread contains a similar issue to what I’ve seen; ( and it holds my systemctl response)
Yes, tried start.sh, sometimes the processes was there forever, sometimes they went away immediately, sometimes they was there for a few minutes. A few times some GUI showed up. But OH never worked.
I’ve seen atleast two threads with the same issue.
syslog says nothing:
pi@homeauto /var/log $ grep openhab syslog*
pi@homeauto /var/log $ grep -i openhab syslog*
A fault that is so severe that you have to resort to reinstalling is pretty serious. And as we do that, all information needed to do an RCA goes out the window.
Reporting issues here is twofolded for me, yes I want them resolved. But first and foremost I want to make the product better. And I think that the process of moving from cases in this forum to code improvements could be strengthened.
As for your specific question on documentation:
I come from OH1 and I would like to throw the Paper UI as far as I can. Or provide an import utility to move all files into the database.
For instance, being a novice in the tools and trying to edit stuff when the UI doesn’t reflect the updates is a nightmare: Did I do something wrong or is the tool at fault, Should I try again? or something else?
If OH should make an impact on the IoT stage, the installation and admin must be rock solid, coherent and hazzle free. Not a lot of jumping between PaperUI, habmin and good old vi combined with guessing.
The documentation should provide one solid way for doing this.
And if needed, the GUI’s should adapt to that one seemless way of working.
my 2 cents.
