So i gave up with the hue emulation and google home. Thought I’d try with the weather. Installed the Yahoo Weather binding. followed the docs on setting it up and it never would pull any weather. So I tried to set up the weather binding. I copied the demo items and set up from the docs page, read several forums and tried several different things but Wunderground weather will not get the weather. It’s extremely frustrating when you can’t get something to work even after following the instructions.
I have the Astro binding set up and it gets the sunset and all that.
Here’s my weather.cfg
weather:apikey.Wunderground=XXXXXXXXX
# location configuration, you can specify multiple locations
weather:location.home.name=Home
weather:location.home.latitude=35.0906884
weather:location.home.longitude=-89.9451742
#weather:location.home.woeid=
weather:location.home.provider=Wunderground
weather:location.home.language=en
weather:location.home.updateInterval=10
For the record: my stated issue with mqttitude not working, causing lots of work for others, came down to a mistake I made: a typo.
My learning: go with a comb through the changes before posting!
@tdsheppard77, for the weather binding it is a 1.x binding, and hence the weather docs reference the config for 1.x where everything was stored in a single config file. For openHab2, there are separate config files, so you don’t have to prefix the settings with the binding names.
So in your weather.cfg file use the following (note the weather. prefix is removed):
#location.home.woeid=
I also updated the existing ticket about documenting the 1.x bindings with these details. hopefully as this ticket gets worked on this detail will be addressed.
Hi Max,
I’m in a pretty similar boat to you. Seasoned programmer in ASP, PHP and other scripting language. Started programming in 1979 (basic if anybody remembers that). Spent the last 20 years in IT.
I installed OH2 from apt-get on raspberry pi (offline) in about 35 minutes and got everything to show up. I have a working web interface. My Mosquito broker is running on my windows machine (just because it was easy to get it done quickly)
I have however, spent the last 3 days trying to figure out how to add the MQTT binding and my sonoff unit to the interface, but alas, I’m totally lost.
Do you mind sharing how you setup mqtt with openhab2?
I currently have the demo enabled and making the changes to the demo in order to understand how the structure works.
I have my own “floor” in the main layout, clicking on my floor i get to my room and I see the light switch.
inside the demo.items file i have:
Switch Sonoff1 “My_Study” (gTFloor) {mqtt="<[mymosquitto:/test/sonoff:state:default"}
I am not sure that the mqtt broker is setup correctly (where does it get defined?) and i am not sure if the text inside the curly brackets is correct.
I believe everything is nicely discussed there. If you go a bit up, you’ll see, that I promissed to write a tutorial soon. I’ve ordered a dozen new Sonoffs.
It will fetch the weather data automatically. What does your log show for the weather binding (weather data is updated each time you save the weather.cfg file). Also, I assume your binding is installed correctly and not showing any errors?
One other thing with Wunderground - I don’t what its like where you are, but Wunderground has recently been flaky for both myself and another user here in London, frequently giving missing api key errors etc. It may be worth trying another provider such as forcastio.
Looks like it’s giving an error. Incomplete location config for location ID.
My understanding after reading the docs…to install the weather binding you just add weather1 to the bindings list in the addons.cfg file. It doesnt’ show up in the paperui under bindings. The docs don’t say anything about adding anything to the .things file like you do with other bindings.
2017-01-18 15:37:42.553 [WARN ] [eather.internal.common.WeatherConfig] - Incomplete location config for locationId 'Home'. Check openhab.cfg.
2017-01-18 15:37:42.560 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler, id=300, bundle=185/mvn:org.openhab.bin$
org.osgi.service.cm.ConfigurationException: weather : Incomplete location config for locationId 'Home'. Check openhab.cfg.
at org.openhab.binding.weather.internal.common.WeatherConfig.parse(WeatherConfig.java:97)[185:org.openhab.binding.weather:1.9.0.201701160210]
at org.openhab.binding.weather.internal.bus.WeatherBinding.updated(WeatherBinding.java:82)[185:org.openhab.binding.weather:1.9.0.201701160210]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1461)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1417)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
I don’t know how carefully Designer checks cfg files. For example, if you have location.home.latitude=12.345678 and location.Home.longitude=-123.456789 Designer would be fine with that but it would be an error (case matters).
There is nothing I can see wrong with that config.
Given the myriad of problems you have had (I praise you for your perseverance) I’m wondering if there isn’t something more fundamental going on. Are you running this on a Raspberry Pi? Perhaps the SD card is failing…
In openHAB 2.0 there is no openhab.cfg. That massive monolithic catch all file used to configure OH 1.x and all its bindings has been split up into separate cfg files for each binding. Assuming you didn’t create one (it would be located either in your root config folder or in the services folder) there isn’t one.
That error message comes from a 1.9 version binding so it assumes it is running on 1.x and therefore assumes there is an openhab.cfg.
If you are on a Pi I really do strongly recommend trying another SD card. These inexplicable errors almost always point to a failing card. Symptoms others have seen:
saved files reverting to the previous version
correct files being parsed incorrectly
changed files not being updated
unexplained errors in the logs
bindings not installing
bindings installing then disappearing
When the SD card starts to go your machine enters bizzaro land.
And the card does not have to be old to fail like this.
I found the issue. another forum user had a similar issue and said that he found a file weather.config file in the cache folder. He deleted it and the weather worked. I didn’t find that file in the location he did but I did find it in <user_data>/config/org/openhab/weather.config I deleted the file and now the weather works.
