I had the sensor working several months ago then removed it from my Rpi3 which has the Aeotec Z stick and ZW100 sensor attached. I am running openHAB2.4, sensor is 1.9. I believe I followed the inclusion instructions correctly, but a few things seem different. I am using the Paper UI.
- When searching for the sensor the inbox always shows two instances of the sensor on two different nodes.
- When I add one as thing, one at a time to test, only one shows as online.
- I see the correct channels, but I do not understand what to link each with - I do not remember having to do this last time, I had just picked each one and with the check mark chosen they appeared in the control section as things, and showed the readings for the 6 sensors.
Any feedback is appreciated.
Tom
