a device “MP707R” - 2 relay 5 and temperature sensors.
Management used by Linux.
the commands themselves light
:~# bmcontrol pset 1 1 / turn on first relay* Status port changed :-# bmcontrol pset 1 0 / turn off first relay* Status port changed :-# bmcontrol ports Port1 is on Port2 is off ~# bmcontrol temp 580000047ac2a928 15.000000
in sitemap all OK /* i think
sitemap name label="OpenHAB" { Frame label="my House" { Group item=gMP label=“Home” icon="cellar" } Frame label=“Date”{ Text item=Date Text item=Time} }
but next step need help in items
Group gMP (All) Group MP707R “MP707R, rele 2 channel” (gMP)
Number Temp "Temp [%.1f °C]" { exec="<[bmcontrol temp 580000047ac2a928:60000:]" }
Meaning:
Execute bmcontrol temp 580000047ac2a928 every minute, and use the string returned as the number to set as the state of the Temp item. See the Exec Binding documentation for more information.
thanks its worck
Number Temp_board “Board:[%.1f °C] " (MP707R) { exec=”<[bmcontrol temp 580000047ac2a928:30000:]" }
but i try make Switch on/off
ON: [INFO ] [runtime.busevents ] - MP707R_R1 received command ON [INFO ] [.o.b.exec.internal.ExecBinding] - executed commandLine 'bmcontrol pset 1 1], >[OFF:bmcontrol pset 1 0’
result on system - nothing, rele still off
OFF: [INFO ] [runtime.busevents ] - MP707R_R1 received command OFF [WARN ] [.o.b.exec.internal.ExecBinding] - doesn’t find matching binding provider [itemName=MP707R_R1, command=OFF]
patience and again patience, I can not cope, it really wants to get results quickly. Thank you very much, this is a working version.
Hopefully my mistakes and your tips will save time for others suffering
