That’s what I thought! technically, rules are for automation and I should be able to control a thing with just an item and its corresponding entry on a sitemap right?
The binding logs its status when loaded. Noted.
Sorry, I did not realize there was a difference. At this point, I just need something simple just to test. Toggle would be fine. What would I use with “Switch sq_test_play”?
