All,
I would like to compare two numbers in a rule when the according item changes:
rule "Heat_HzSoll check"
Item Heat_HzSoll changed
if(Heat_HzSoll.state >= Heat_HzSoll.previousState(true,"jdbc") as Number) {
if(Heat_HzMode.state == "night" && G_Melder.state == ON) {
if(Z_Alexa.state == ON && AmazonThing.state == ON) Alexa_Text.sendCommand("Die Heizung soll hochgestellt werden aber die Fenster sind offen. Bitte prüfen.")
logInfo("heating.rules: ", "Heating Temp increased, but windows open (Night Mode)!")
but I get
Rule 'Heat_HzSoll check': Could not cast org.openhab.core.persistence.internal.QueryablePersistenceServiceDelegate$1@13fed0c to java.lang.Number; line 490, column 36, length 48
als this does not work:
if(Heat_HzSoll.state as Number >= Heat_HzSoll.previousState(true,"jdbc") as Number) {
nor this:
if(Heat_HzSoll.state >= Heat_HzSoll.previousState(true,"jdbc")) {
