please, I need a smart idea how to exclude a zwave device from a Razberry Zwave Module running on a Raspberry Pi 4 openHABian.
I already tried the following:
- HABmin: set device is FAILed, then Remove device from controller - no success (Error-Message: [ERROR] [message.RemoveFailedNodeMessageClass] - NODE 6: Remove failed node failed as Controller Busy!)
- Added a secondary controller attached my Widows 10 PC to delete the device - not possible
Does anybody know of a (command line) tool running on Linux where I do not need to install hundred of packages?
Any other ideas welcome.
Thanks in advance for your help.
