I have an Aeotec Z Stick and 3 Z-Wave devices - a siren and two identical door/window sensors (D-Link Z110).
There are 2 issues I’m facing:
I managed to successfully bind one of the door sensors but the second one will not bind. I add the device to the ztsick, the lights on the sensor and the zstick indicate pairing is successful but the logs show:
2017-07-30 09:36:27.768 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-07-30 09:36:32.777 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-07-30 09:36:37.785 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-07-30 09:36:42.793 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-07-30 09:36:47.801 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-07-30 09:36:52.808 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-07-30 09:36:57.816 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
The door sensor that did bind correctly does not report any data. It has Contact Type, can sense temperature and see luminescence but all 3 values report as either null or 0.0 and I cannot see anywhere in the events log where they have every changed.
Any ideas?
P.S I have edited my post as I managed to resolve one of the issues.
Please enable debug logging for the ZWave binding and I’ll take a look at this. To do this from Karaf, use the following command log:set DEBUG org.openhab.binding.zwave.
Did you already solve the problem? Ive got the same error.
I have 5 pop thermostats running and 3 switches. It works fine for 18 days with no updates or changes. Only the 5 thermostats to test the config. But after 18 days the system gets errors and after a restart of the service or an reboot of the system.
The error arrived after a few hours. And won’t go away.
So when this happend i can reboot every two ours to keep up the zwave stick and binding running.
Im using a Aeon stick plus. And a RPI3 with raspbian 2.1.0-1 (Release Build) on it. My anel relays binding works stil fine and the squeezebox binding also. Rfxcom binding is no problem with usb. Only the zwave gets I/O errors.
Is it an option to run openhab at an other device as an RPI3?
Otherwise i must buy a tado system with new thermostats. To have a heating home with no worries and a happy wife And do everything with openhab accept zwave.
2017-10-31 09:25:40.068 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-10-31 09:25:45.073 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2017-10-31 09:25:45.078 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
My issue was resolved by waking the z-wave device up multiple times and then leaving it for a number of hours. I have two of the same sensors and had to do the same for both.
