- Platform information:
- Hardware: QNAP 469L
- OS: Linux
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
HELP
I am currently running a Domoticz on my NAS 169L with a Mosquito 1.4.10 MQTT with no username/pw ( at least i dont know as i did not set anything in Mosquito nor in Domoticz)
I installed in parallel OpenHab 2.5.3 with Java 1.8.241.1
I set up MQTT binding and MQTT broker binding. Connection obviously seems ok - as indication light is green.
I connected item (sonoff switch) - and tried to switch on and off - but doesn’t work
With an MQTT sky i can see communication between domoticz and sonoff, however i cannot see any MQTT command from openhab …
I am not a profi at all - however I have good basic knowledge (i think as i managed it with domoticz) - where do i have to search for the failure … what info do you need to support my investigation … ??
hope to get hints from you …
