I have lighting rules that I would like to use lambda expressions for to save duplication of code. Will I have to pass in all the required items the rule will act on, or is there a way to avoid that since the item names all follow a set format? Would I be able to pass in “All_Lamps” or “G_Livingroom_Lamps” and have the code append _Whitemode, _Discomode and _Dimmer where appropriate to form the required item names?
I’ve pasted two of the four rules (as they are identical except for the items they act on).
Any guidance would be greatly appreciated.
rule "Light Scenes0"
Item Lights_scene0 received command
if (receivedCommand==0) {
sendCommand(All_Lamps_Whitemode, ON)
sendCommand(All_Lamps_Dimmer, 100)
if (receivedCommand==1){
sendCommand(All_Lamps_Nightmode, ON)
if (receivedCommand==2){
sendCommand(All_Lamps, ON)
sendCommand(All_Lamps_Discomode, INCREASE)
if (receivedCommand==3){
sendCommand(All_Lamps_Whitemode, OFF)
sendCommand(All_Lamps_Dimmer, 25)
if (receivedCommand==4){
sendCommand(All_Lamps,OFF)
rule "Light Scenes1"
Item Lights_scene1 received command
sendCommand(G_Livingroom_Lamps1_Whitemode, ON)
sendCommand(G_Livingroom_Lamps1_Dimmer, 100)
sendCommand(G_Livingroom_Lamps1_Nightmode, ON)
sendCommand(G_Livingroom_Lamps1, ON)
sendCommand(G_Livingroom_Lamps1_Discomode, INCREASE)
sendCommand(G_Livingroom_Lamps1_Whitemode, OFF)
sendCommand(G_Livingroom_Lamps1_Dimmer, 25)
sendCommand(G_Livingroom_Lamps1, OFF)
end'
Items
Switch All_Lamps "All Lamps" (Lighting) {milight="bridge1;6"}
Switch All_Lamps_Whitemode "All Lamps - Whitemode" (Fancy_All, Lighting) {milight="bridge1;6;whiteMode"}
Switch All_Lamps_Nightmode "All Lamps - Nightmode" (Fancy_All, Lighting) {milight="bridge1;6;nightMode"}
Switch All_Lamps_Discomode "All Lamps - Discomode" (Fancy_All, Lighting) {milight="bridge1;6;discoMode"}
Dimmer All_Lamps_Dimmer "All Lamps - Dimmer" (Fancy_All, Lighting) {milight="bridge1;6;brightness"}
Number Lights_scene0 "All" <switch> (Lighting)
Switch G_Livingroom_Lamps1 "Lamps 1" (G_Livingroom, Lighting) {milight="bridge1;7"}
Switch G_Livingroom_Lamps1_Nightmode "Lamps 1 - Night" {milight="bridge1;7;nightMode"}
Switch G_Livingroom_Lamps1_Whitemode "Lamps 1 - White" {milight="bridge1;7;whiteMode"}
Switch G_Livingroom_Lamps1_Discomode "Lamps 1 - Disco" {milight="bridge1;7;discoMode"}
Dimmer G_Livingroom_Lamps1_Dimmer "Lamps 1 - Dimmer" {milight="bridge1;7;brightness"}
Number Lights_scene1 "1" <switch> (Lighting)'
Site Map
Switch item=Lights_scene0 mappings=[0="On", 1="Night",2="Disco", 3="Dim", 4="Off"]
Switch item=Lights_scene1 mappings=[0="On", 1="Night",2="Disco", 3="Dim", 4="Off"]
