In paper UI there is allready a token entered. So it probably does that automatically.
So not sure what happens when rebooting. in some way it removes it i think.
But its not at all a problem for me, just know now that when i reboot i have to accept the tv notification otherwise websocket doesnt work. And i dont reboot that often.
It is indeed a security token for the websocket communication, that will be obtained automatically. It should be retained during reboots, if not the TV will ask for confirmation again.
Hello there! I think quite a few of us have seen the token disappear on reboots, unfortunately. Do you have any idea what could be causing this? Is there any information you need to help solve this problem? Thanks for taking time to look into this!
EDIT: Now i feel dumb …
It worked with the sourceapp item by just forwarding the name as string …
Thanks mate
Hi!
It did something … My TV asked me if my mac is allowed to control. i hit yes but i am not getting netflix to run. the respond from the terminal is:
Hi there,
I have OH 2.5, installed the last binding and I have:
java.lang.ClassNotFoundException: org.eclipse.smarthome.io.net.http.TrustAllTrustMananger cannot be found by org.openhab.binding.samsungtv_2.5.4.202004190717
I have 3 samsung >2016 , with the 2.4 binding they didn’t work, as u already know.
Any hint to bypass this problem?
Thank you for everything you are doing.
Andrea
Hi, i have a UE50NU7400
I have just upgraded openhab2 to 2.5.4
When i discover the TV and add as a thing, it configure automatically to the port 8002, with Secure Websocket but without the Token field filled.I cannot change any parameter and i didn’t get any info from it, but i receive the change (es The volume get changed via the remote and the change propagate to openhab).
If i change the Protocol to Websocket and the port to 8001, i can change TV volume and set mute via openhab but i cannot turn off and on the tv or do anything else. No data of the application running or program is sent to openhab.
Little update: i uninstalled completely the samsung binding and installed from scratch.
Now the TV get founded correctly and i can do anything (volumes, keys, ecc) except turning it on from being off. From log i see that the magic packet get sent (6 or 7 times).
Any hint then on how call application (Like Netflix or Plex) from openhab?
get this error, if i search on the TV after apps:
2020-05-03 21:36:53.483 [WARN ] [tv.internal.protocol.WebSocketRemote] - WebSocketRemote: Error (java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 39 path $.data) in message: {"event":"ms.remote.imeStart","data":"input"}
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 39 path $.data
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:224) ~[bundleFile:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.read(ReflectiveTypeAdapterFactory.java:129) ~[bundleFile:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:220) ~[bundleFile:?]
at com.google.gson.Gson.fromJson(Gson.java:888) ~[bundleFile:?]
at com.google.gson.Gson.fromJson(Gson.java:853) ~[bundleFile:?]
at com.google.gson.Gson.fromJson(Gson.java:802) ~[bundleFile:?]
at com.google.gson.Gson.fromJson(Gson.java:774) ~[bundleFile:?]
at org.openhab.binding.samsungtv.internal.protocol.WebSocketRemote.onWebSocketText(WebSocketRemote.java:94) [bundleFile:?]
at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onTextMessage(JettyListenerEventDriver.java:231) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.message.SimpleTextMessage.messageComplete(SimpleTextMessage.java:69) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.appendMessage(AbstractEventDriver.java:65) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onTextFrame(JettyListenerEventDriver.java:179) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.incomingFrame(AbstractEventDriver.java:150) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.WebSocketSession.incomingFrame(WebSocketSession.java:321) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.extensions.ExtensionStack.incomingFrame(ExtensionStack.java:202) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.Parser.notifyFrame(Parser.java:226) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.Parser.parseSingleFrame(Parser.java:262) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:582) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:441) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:428) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 39 path $.data
at com.google.gson.stream.JsonReader.beginObject(JsonReader.java:385) ~[bundleFile:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:213) ~[bundleFile:?]
... 30 more
WebSocket is connected but after this i get the warning:
[WARN ] [l.protocol.RemoteControllerWebSocket] - Cannot retrieve current app webSocketV2 is not connected
I wanted to report that after restarting Openhab 2.5.4 running on Windows 10 I have to remove the Samsung TV binding restart again & re install it in order to keep it working.
For me I only use it to detect when the TV(s) is turned on & off to control other lights in the room which works perfectly except after I have restarted Openhab.
Hi @jwiseman,
I suffer this bug with my samsung TV (I really need to get it working because we heavy rely on rules I created to manage TV for kids),
Where do I find the 2.4 RC1 version of the binding? Does it work with openhab 2.5.4 ? What version of JuPnP is suggested?
Yes, lots of differences between the two version. The 2.4 is stable but doesn’t have all the functionality of the 2.5.x version. You would just uninstall Samsung 2.5.x and drop the 2.4.0 RC1 into the Addon’s directory.
Hi Jay,
thanks for swift feedback. I don’t have anything specific installed and just imagine if my system would be run[quote=“jwiseman, post:118, topic:67053”]
[/quote]
Before this I shall be able to find this on frog-repository :-/ but I’m not. Neither package nor quick search or any other brings this one up :-/ HAs it been moved, or do I make something wrong in my search?? I looked for samsungtv-2.4.0.RC1, just as descibed above
Solved, got it. Wasn’t clear to me that I had to include *'s
Did you solve this?
I have the exact same problem and it seems that it is the slash that causes problems.
Try the URL without any slashes “192.168.1.134:81”
It doesn’t solve the problem but it isolates it
Any URL with slashes causes my TV to do a google search where the slash has an backslash before.
Example:
“192.168.2.134:81/ui3.htm” will generate the same OH-error log message as you got and the TV will open a browser for the address “192.168.2.134:81/ui3.htm”
The binding is also going offline, but thats another problem
