String CurrentCostRaw "CurrentCost XML [%s]" { serial="serial:serialDevice:currentCost:displayUnit:rawData" }
The log shows that it connects and I get a serial:serialBridge:currentCost:data triggered PRESSED but the CurrenCost_raw item remains NULL.
Would you know if this is setup correct? I’m struggling with the patterns. I have set .* hoping that will return everything, but it does not. Once I get the hang of this, I am hoping to populate the items via the things file, using regex instead of xpath in the rule. But I’m jumping ahead of myself, as I can’t receive anything at the moment.
Would anyone be able to see what I’m doing wrong? I have been looking at this for many hours!
Well, that was silly! Can you spot the mistake . It’s working now! Once I get this all working properly I’ll share it, as it may be of use for others.
Hi, please share your things file as well as with site and items.
I’m struggling to send commands and get NULL as well.
Yes, I have “channels” and not serial as in your mistake
Just a note. But when pressing binding information in openhab, the page for binding 1 opens up.
Is there another binding in OH3 that is not available in OH2.5 that utilizes .things file?
