[SOLVED] Help to create a rule "turn on a lamp when motion is detected but only after sunset until sunrise"
Hello Community,
i would like to create a simple rule, when motion is detected turn the lamp on, but only when it is after sunset ore a time like after 19:00.
at first i have created a rule like:
rule " Light on when motion is detected"
Item Motion_GF_Corridor_Stiege received update ON
Light_FF_Stiege.send command(ON)
this rule is working
than i have tried:
and
Item Sunset_Time received update ON
here i get error rule is either empty or cannot be parsed correctly
i have also tried a rule like this:
Channel 'astro:sun:home:set#start' triggered START
if Item Motion_GF_Corridor_Stiege received update ON
this is also not working, i get here the same error in the losg.
maybe someone can help me with this rule.
kind regards,
martin
As a start Iā€™d look into
This post
You can look at the post above or you can use a flag item
Please feel free to name it as you want
Items file:
Switch flagItem
Rules file:
rule "Set 1900 or Sunset flag"
    Time cron "0 0 19 * * ?" or
    Channel ā€˜astro:sun:home:set#startā€™ triggered START
    flagItem.sendCommand(ON) //sets flagItem
rule "Turn Off flag item"
    Time cron "0 0 6 * * ?" //6am
    flagItem.sendCommand(OFF) //resets flag item at 6am
rule " Light on when motion is detected after 1900 or sunset"
    if (flagItem.state == ON) {
        Light_FF_Stiege.sendCommand(ON)
Also next time, try yo use the code fences as it help reading your code:
Good luck
Thank you very much, it is working with the flagItem :slight_smile:
And the Idea with the Switch is also great, so i can tur it off and on manually if i want :grinning:
Iā€™m new to OpenHab and in the process of migrating from SmartThings.
Iā€™m looking to do a similar thing and wondered how the rule given might be extended to turn off the light after a set time interval, of say, 5mins?
Youā€™ll find all the info you need in:
The expire binding is very easy to use and very reliable
My only gripe with it is that the time delay are in the code and not adjustable at run time
Good luck
