hi
i have en raspberry 3 and razberry z-wave controller card but i can´t find my z-wave item in the Z-Wave Serial Controller item setup it ask for seriel port where du i find this
pleas help i am new in openhab 2.0
hi
regarding to:
http://www.homeautomationforgeeks.com/openhab_zwave.shtml#zwave
it might be:
/dev/ttyAMA0
Easiest way to find it is to plug it in and run ls /dev/tty*
. Then unplug it and run that command again. The Item that disappeared is the serial port for the controller.
i have tryed this things but i still get this Status: OFFLINE - COMMUNICATION_ERROR Serial Error: Port /dev/ttyAMA0 does not exist
Have you used the following command?
sudo usermod -a -G dialout openhab
