Trying to get some stuff to run locally, and following instructions from this forum, added the following to my X.things file:
exec:command:kitchenlight “TP-Plug Switch” [command="/enlistments/TpLink/TpLink/TpLink/bin/Debug/tplink.exe %2$s", interval=0, timeout=5]
exec:command:kitchencheck “TP-Plug Status” [command="/enlistments/TpLink/TpLink/TpLink/bin/Debug/tplink.exe check", interval=15, timeout=5, transform=“REGEX((.*?))”]
Along with various combinations of commenting them out. Even when I enabled the first thing, which does not have any transformation specified, I got the following lines in the log:
3:10:50.943 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type REGEX
23:10:50.943 [WARN ] [hab.binding.exec.handler.ExecHandler] - Couldn’t transform response because transformationService of type ‘REGEX’ is unavailable
23:10:50.959 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type REGEX
23:10:50.960 [WARN ] [hab.binding.exec.handler.ExecHandler] - Couldn’t transform response because transformationService of type ‘REGEX’ is unavailable
This went away after I installed the REGEX transformation, but why did I have to install it if no transformation was specified?
