adm105
(hjs)
April 5, 2022, 9:02am
1
Hello community,
I created the following widget myself:
uid: Batterie_Status_v2
tags: []
props:
parameters:
- description: Eine Überschrift festlegen...(<u>Vorschlag:</u> <b>Batterie Status</b>)
label: Batterie Status
required: true
type: TEXT
- description: Item-Bezeichnung oder leer wenn disabled (<u>Vorschlag:</u> Samsung Tablet</b>)
label: Samsung Tablet
required: false
type: TEXT
- context: item
description: Item wählen oder leer wenn disabled (<u>Beispiel:</u> <b>BatteryLevel</b>)
label: BatteryLevel
required: false
type: TEXT
advanced: false
parameterGroups: []
component: oh-list-Card
title: =props.prop1
simpleList: false
mediaList: true
slots:
default:
- component: oh-label-item
item: =props.item2
title: =props.prop2
icon: =props.icon4
iconUseState: true
How do I configure iconcolor with f7-icons battery_0, battery_25 and battery_100 so that the color <=20% is red, <=50% is yellow and <=100 is green?
Thanks for your support.
rlkoshak
(Rich Koshak)
April 5, 2022, 2:05pm
2
If you are using OH Icons the icon selected is based on the file name.
If you are using icons from any other source, you have to use an expression in the icon color property. See Building Pages - Components & Widgets | openHAB and lots of additional examples are available on the marketplace.
adm105
(hjs)
April 5, 2022, 6:59pm
3
I have now tried various options and had no success. Maybe another user has an idea what I’m doing wrong. Here is my last non-working code:
uid: Batterie_Status_v7
tags: []
props:
parameters:
required: true
type: TEXT
required: false
type: TEXT
- context: item
label: BatteryLevel
required: false
type: TEXT
advanced: false
parameterGroups: []
title: =props.prop1
simpleList: false
mediaList: true
slots:
default:
item: =props.item2
title: =props.prop2
icon: "=(props.icon4.state <= 20) ? 'f7:battery_0' : (props.icon4.state <= 50) ? 'f7:battery_25' : 'green'"
iconColor: "=(props.icon4.state <= 20) ? 'red' : (props.icon4.state <= 50) ? 'yellow' : 'green'"
iconUseState: true
rlkoshak
(Rich Koshak)
April 5, 2022, 7:02pm
4
An icon doesn’t have a state. An Item has a state. Your expression needs to test the state of the Item, not the icon.
adm105
(hjs)
April 5, 2022, 11:13pm
5
Thanks for the support, the widget is working now. For anyone interested in the correct code, here it is:
tags: []
props:
parameters:
required: true
type: TEXT
required: false
type: TEXT
- context: item
label: BatteryLevel
required: false
type: TEXT
type: TEXT
advanced: false
parameterGroups: []
timestamp: Apr 5, 2022, 2:49:38 AM
title: =props.prop1
simpleList: false
mediaList: true
slots:
default:
item: =props.item2
title: =props.prop2
icon: '=(items[props.item2].state <= 20) ? "f7:battery_0" : (items[props.item2].state <= 50) ? "f7:battery_25" : "f7:battery_100"'
iconColor: '=(items[props.item2].state <= 20) ? "red" : (items[props.item2].state <= 50) ? "yellow" : "green"'
iconUseState: true
