Hi everyone
im trying too create a guest mode using a rule
when guestmode changed to on
remember status of all items
then change some items…
when guestmode is turned off
set all the items back too the remembered state
rule so far
rule "Guest Mode Enable"
Item GuestMode changed to ON
//remeber status of all items about too change
GDisable.sendCommand (ON) // group item that contains switces too disable automations
createTimer(now.plusSeconds(10), [|
DisableAmeliasTvButton.sendCommand (OFF) // member of GDisable that doesent need turning off
DisableTylersTvButton.sendCommand (OFF) // """"
DisableTylersRules.sendCommand (OFF) // """"
DisableAmeliaRules.sendCommand (OFF) // """"
DisableSystemWarning.sendCommand (OFF) // """"
DisableServerDoorWarnings.sendCommand (OFF) // """"
DisableKidsRules.sendCommand (OFF) // """"
DisableServerRackWarning.sendCommand (OFF) // """"
LrLightLock.sendCommand (ON) // Stops living room lights from changing
PartyMode.sendCommand (ON) // enables legacy rule too be remomoved soon
GLRSpeakerLights.sendCommand ("19,100,50") // sets livingroom lights on
LivingRoomLamp_Brightness.sendCommand ("50")
rule "Guest Mode Disable"
Item GuestMode changed to OFF
// set items back too rememebered state
I haven’t got a clue how too do the remember and restore of items little experience with using historic states
