Help with counting active items in a group
I have a quick question about counting active items in groups. I have a bunch of items defined as such, which refer to loads each ranging from 0 (off) to 1-100 (on). I would like to count the active nonzero loads:
Dimmer mod00ld0 "Module 00 Load 0" (gLoads)
Dimmer mod00ld1 "Module 00 Load 1" (gLoads)
Dimmer mod00ld2 "Module 00 Load 2" (gLoads)
I need something like below, but I cannot arrive at the correct syntax:
Group:Number:EQUAL(not 0)    gLoads  "Number of active nonzero loads [%d]"
Can someone offer a suggestion? Thanks.
Try it with OR only Values not 0 will count
My understanding is that Group aggregation functions do not currently provide what you are looking for. An alternative would be to create another item and update it with a rule.
Number    Active_Load_Count    "Active load count [%s]"
rule "Update active load count"
    Member of gLoads changed
    if (triggeringItem.state == 0 || previousState == 0) {// this could be removed, but will help reduce load with frequent changes
        Active_Load_Count.postUpdate(gLoads.members.filter(item | item.state > 0).size)
If you are not currently using a recent OH 2.3 snapshot, you’ll need to replace the ‘Member of’ trigger with a trigger for each item within gLoads.
