So i am wondering if this scenario is possible using a forEach code. Here is how i am set up.
I have some SONOS One’s and Echo Dot with Alexa integrated to it. I also have rules that when my doorbell is rung or washer is complete, etc it notifies me over TTS.
I am currently using a forEach command to set the volumes to a constant number of the SONOS / Echo Dot state and looping it to everything in the group with the forEach command.
What I am wondering, is it possible to use a forEach code to grab each individual volume and set it to another item in a totally different group.
Dimmer Echo_TV_Room_TTS_Volume "TV Room Text to Speech Volume [%s]" (gTVRoom_EchoDot, gSonos_TTS_Vol)
Dimmer Echo_TV_Room_Music_Vol "TV Room Music Volume [%s]" (gTVRoom_EchoDot, g Sonos_Music_Vol)
So what i want is to loop through the members and and grab the _Music_Vol from each item then assign it to to same name’s _TTS_Volume.
I don’t know if i am asking this correctly or if this is even possible. I am looking to save myself from writing a lot of small code for each individual sonos player / Echo Dotso whenever one item is updated it updates the other.
