I have a few of the GE 12724 dimmers. When I try to increase or decrease the dim level via the web interface, it either doesn’t respond or the dim level will not go up very much - 5-10%. I’ve played around with the items based on various things I’ve found with no luck.
My current items:
Dimmer Light_Corridor_Dimmer "Hallway Dimmer [%d %%]" {zwave="2:command=SWITCH_MULTILEVEL,refresh_interval=600"}
Switch Upstairs_Hallway "Upstairs Hallway" {zwave="2:command=BASIC,refresh_interval=600"}
Dimmer Light_Office_Fan_Light "Ceiling Fan Light Dimmer [%d %%]" {zwave="3:command=SWITCH_MULTILEVEL,refresh_interval=600"}
Switch Fan_Light "Ceiling Fan Light" {zwave="3:command=BASIC,refresh_interval=600"}
Dimmer Light_Office_Recessed_Dimmer "Office Recessed Lighting Dimmer" {zwave="4:command=SWITCH_MULTILEVEL,refresh_interval=600"}
Switch Office_Recessed "Office Recessed Lighting" {zwave="4:command=BASIC,refresh_interval=600"}
My current sitemap:
sitemap demo label="This House"
Frame label="Upstairs" {
Text label="Office" icon="attic" {
Frame label="Hallway Lighting" {
Slider item=Light_Corridor_Dimmer label="Upstairs Hallway Dimmer"
Switch item=Upstairs_Hallway label="Upstairs Hallway"
Frame label="Office Lighting" {
Switch item=OfficeMood label="Office Mood Lighting"
Slider item=Light_Office_Fan_Light label="Ceiling Fan Light Dimmer"
Switch item=Fan_Light label="Ceiling Fan Light"
Slider item=Light_Office_Recessed_Dimmer label="Recessed Lighting Dimmer"
Switch item=Office_Recessed label="Recessed Lighting"
Frame label="Outside" {
Text label="Outside" icon="garden" {
Frame label="Front Lights" {
Switch item=FrontDrive label="Front Drive"
Switch item=FrontPorch label="Front Porch"
Is there a way to poll the switch to determine current dim level and have it display on the web interface?
What exactly does “[%d %%]” do?
Thanks.
